Replacing shift knob...
Old Sep 30, 2004 | 06:21 PM
eboler's Avatar
eboler
Default Replacing shift ****...
I'm sure this has been posted a million times, so sorry in advance but how do you remove the stock shift ****. I have been told by people who own other cars that they just have had to pull, but wanted to make sure there wasn't anything different with vettes. I have an 86 manual.
thanks!
Old Sep 30, 2004 | 07:07 PM
myblue91's Avatar
myblue91
Should be the same for a 91'. Pry up the plastic **** and remove the long clip(don't know what it's called) and then there's a c-clip that's next, then pull **** off.
Old Sep 30, 2004 | 07:09 PM
eboler's Avatar
eboler
okie dokie, thanks!
Old Sep 30, 2004 | 07:22 PM
86_Vette's Avatar
86_Vette
Do you have the 4+3 with the od button on the top of the shifter ****? On the manual vettes they unscrew, but there a few steps before you get to that part.
Old Oct 1, 2004 | 01:06 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
No way. Hey!
Old Oct 1, 2004 | 09:37 AM
eboler's Avatar
eboler
Yes, I do have the 4+3 OD button. How do I go about removing that?
Old Oct 1, 2004 | 11:06 AM
86_RedRider's Avatar
86_RedRider
Cruise-In V Veteran
St. Jude Contributor '03 & '05
first, pop off the button, then pull out the metal wedge. next, there should be a skinny shaft that runs down the length of the shifter (this is what connects the button to the o/d switch), start twisting this shaft until it comes out, now you should be able to unscrew the ****.
Old Oct 1, 2004 | 12:51 PM
86_Vette's Avatar
86_Vette
Old Oct 1, 2004 | 06:25 PM
eboler's Avatar
eboler
thanks guys... i'll post again if i have anymore probs.
To Replacing shift knob...
