changing fuel filter
Old Oct 10, 2004 | 05:29 PM
94snakeater's Avatar
94snakeater
Default changing fuel filter
is it hard to change out the fuel filter. where is it located on the lt1 versions.
Old Oct 10, 2004 | 05:57 PM
jabez's Avatar
jabez
Not hard to do but kinda hard to get to and can get a bit messy.
Located back end of car. If you have a lift its easy to see and replace.
Old Oct 10, 2004 | 06:08 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
fuel filter is located on the passenger side on the frame right next to the catalytic converter.
Easier to change if you can get the car on a lift.
Old Oct 10, 2004 | 06:21 PM
FX GS's Avatar
FX GS
Took me about 20 minutes, with only one knuckle scrape
Old Oct 10, 2004 | 06:53 PM
Perfusion's Avatar
Perfusion
On my 96 (LT4), if you lay on the ground on the passenger side and look under the door - just next to the frame rail - you'll see the two fuel lines. Follow them forward and up it goes up towards the motor around the RF tire, and you should see a soupcan-sized cylinder. That's it.
Old Oct 10, 2004 | 07:31 PM
The Admiral's Avatar
The Admiral
Back end of the car?
Nope - it's not there on a LT1. Like others have said - up near the passenger side cat. If you have a convertible you will need to drop the X-Brace first (2 man job).
Make sure you pull the pump fuse or disconnect the battery first. Have a good set of line wrenches on hand. Make sure the car is cool - that cat gets pretty damn hot!
Old Oct 10, 2004 | 09:56 PM
Ghostpilot's Avatar
Ghostpilot
Plan on fuel leaking and running down your arm. Even after you depressurize the sys. So be well ventilated and have something to catch it. The bottom line is easy to get loose but you will have to crow foot the top line and turn the filter from the bottom. Yes those cats get hot so do it when it's cool. Good luck
Old Oct 11, 2004 | 02:53 AM
vetteweiser's Avatar
vetteweiser
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'13- '14
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
myself and MY 95 changed my filter earlier this year. We had my car (93) up on ramps and it was a PITA to get the old one out, since gas kept drippin in our eyes. What we did was pull the fuel pump fuse, loosen the gas cap and cranked the engine. It still dripped, but I eventually got it. Thank god I have a tolerance of gas in the eye
here, check out this thread for how it looked...
http://forums.corvetteforum.com/show...ht=vetteweiser
Old Oct 11, 2004 | 09:37 AM
gt306's Avatar
gt306
On my 94, its on the passenger side fuel rail.
Old Oct 11, 2004 | 01:39 PM
runner140*'s Avatar
runner140*
Default Follow vetteweiser's post
Vetteweiser covered it perfectly. The fuse----Loosen the gas cap----start the engine etc. Also have a lot of towels ready.
Old Oct 11, 2004 | 04:28 PM
RoadReady's Avatar
RoadReady
On my '96 the oil pressure switch is also on the fuel pump fuse. Pull it and the engine won't crank. GM engineers had one good good idea: lose oil pressure, lose ignition
To changing fuel filter
