Hello! I just bought an 89 Coupe, and am having some trouble with the heater. It never blows hot air. I've let the car run for 15 - 20 minutes, and it never even got warm. Also, I noticed that the air conditioning compressor continues to go on and off at regular intervals weather I set it to 60 or 90. Does anyone have any suggestions on what I should check? Thanks!
Assuming the air is flowing from the correct vents, the heater core is probably plugged and when that happens, water flows over the top of the core, but not through it. You can try to flush it by disconnecting the hoses and hooking up a garden hose to it, or use compressed air, but most need to be replaced. Also, check out the condition of the coolant. If it it looks bad, replace it and keep a close eye on it as the '89 head gaskets can leak and set up galvanic corrosion (which is one of the reasons the heater core plugs up).
A/c compressor should cycle less than 8 times per minute and really not at all if it's above 70 degrees with engine at operating temp. If it cycles more than this, the charge is usually low. Look for compressor oil on the hood above the compressor. If it's there, the shaft seal is shot and needs to be replaced (kits are available at NAPA for about 50 bucks). Otherwise, the Evaporator may be leaking. Any frost on the windshield? Best to have it pressure/leaked checked either at an a/c shop or if you have access, with a manifold gage set.
No, but you gat your ***** kicked with hurricanes and that kind of weather is not conducive to nice rides in the Corvette. Glad to see you are ok there though.
Thanks for the info! I'll check on the core ASAP. It's about to be put away for the winter, but I'd like to get the problem taken care of before I do.
As for moving to FL, Well, if I did that, I wouldn't need to have 2 vehicles, and could afford a much newer vette. However tempting that is, I think I'll stay here in PA.
This is a great forum! Thanks for your quick replies!
so how hard is it to change the heater core. mine doesnt get very got either. the coolent is good and the ac doesnt realy come on unless i turn it on. it gets warm just not hot. 94 coupe
Heater core is tackled from the inside, passenger side, lower firewall. It involves removing whatever is in the way, unbolting the front half of the heater/a/c plenum and removing the core. First step is to remove the hush panel covering the underside of the passenger's dash. That will let you see what else needs to come out to access the heater box screws.
My Mercedes did that. Problem, there wasn't enough coolant in the engine to get into the heater core. (Bad water pump).
Chk the valve to see if its hot. If its hot on one end and not the other the valve doesn't work. Chk both hoses one is hot in the other is cooler out.
Usually a core that is bad will leak. If its blocked then you'll have to replace both the heater core and the radiator. They will both be blocked since they're both on line together.
