Tablets in the Cooling System
I'm thinking about doing a flush on the system. Is the cooling system on Vettes that crazy?? What are these tablets?? What do they do?
you can get em at any gm dealer or parts store.just ask for gm pellets.
its a good idea to add a couple to fresh antifreeze when flushing.
put it this way. they dont hurt.
they are stop leak,and mobil 1 is oil.
nothing different about the colling system as far as flushing goes.
same as any other car,if you have a seep thats about to show up then flush the system,you will find it.
unless your having an issue,dont stir that pot imho.
Eric
pretty much sums it up.did any c4 come with dexcool in it?
not that its bad,just that i never thought it was a good idea to switch from the green stuff to dexcool.
if you do you could very easily see some "sludging".
DO NOT put them into the overflow tank at the bottom of your nose. And don't freak out when they turn your coolant slightly darker. That's normal.
I think that 95 and 96 C4's use Dexcool so earlier cars need the ethlyene glycol (green) coolant. I have used Prestone for years and has worked well in everything. Use a 50-50 mix of coolant and distilled water in the final fill. That provides protection to about -37 degrees.
I also looked on CAC in their knowledge base and didn't see any TSB on this. I don't have a mygmnow member but do they list all applicable TSBs?
i will go check the tsb's and see what i can dig up.
yes,just use good ol green stuff mixed with distilled water.
ok-under this heading
EX-COOL Engine Coolant Information #00-06-02-006A - (Feb 13, 2004)i found this pellet info:
Cooling System Sealing Tablets (Seal Tabs) should not be used as a regular maintenance item after servicing an engine cooling system. Discoloration of coolant can occur if too many seal tabs have been inserted into the cooling system. This can occur if seal tabs are repeatedly used over the service life of a vehicle. Where appropriate, seal tabs may be used if diagnostics fail to repair a small leak in the cooling system.
When a condition appears in which seal tabs may be beneficial, a specific bulletin may be released describing their proper usage. After performing specific procedures outlining seal tab usage, install an appropriate identification label to indicate that the seal tabs have been installed. If seal tabs were installed in the cooling system during assembly, the recommended amount may be added if the cooling system is drained and refilled during a service event. The recommended number of seal tabs depends on the capacity of the cooling system. Use between 1 and 1-1/2 grams of seal tabs per liter of cooling system capacity.
what they are saying is dont add the things unless you changed the coolant.note thats for dex-cool and is from 2004 so is not c4 specific info.
but-(hope this isnt to long guys sorry) -check this one out:
INFO. ON DEX-COOL (TM) ENGINE COOLANT #53-62-02 - (Nov 13, 1995)
SUBJECT: INFORMATION ON DEX-COOL(TM) ENGINE COOLANT - INFORMATION ON BACKSERVICE
MODELS: 1994-95 PASSENGER CARS AND TRUCKS
A NEW EXTENDED-LIFE ENGINE COOLANT CALLED DEX-COOL(TM) IS CURRENTLY BEING USED IN ALL GENERAL MOTORS' VEHICLES (EXCLUDING CHEVROLET GEO AND SATURN). REFER TO BULLETIN 53-62-01 FOR GENERAL SERVICE INFORMATION.
**BACKSERVICE**
DEX-COOL(TM) MAY BE USED IN GENERAL MOTORS VEHICLES ORIGINALLY BUILT WITH CONVENTIONAL (GREEN) COOLANT WITH THE FOLLOWING CONSIDERATIONS:
* VEHICLES ELIGIBLE FOR BACKSERVICE ARE 1994 AND 1995 MODELS (EXCLUDING 1994 J BODY WITH 4 CYLINDER ENGINES).
* THE SERVICE INTERVAL FOR DEX-COOL(TM) INTRODUCED INTO AN OLDER MODEL VEHICLE ORIGINALLY BUILT WITH "GREEN" COOLANT WILL BE 2 YEARS/30,000 MILES (50 KM) (NOT 5 YEARS/100,000 MILES (160,000 KM)).
* ALL THE "GREEN" COOLANT MUST BE REMOVED FROM THE COOLING SYSTEM BY MEANS OF A SYSTEM FLUSH. THIS MAY BE ACCOMPLISHED WITH A WATER FLUSHING DEVICE OR A GMDE WATERLESS COOLANT CHANGER (USE A UNIT DEDICATED TO "GREEN" COOLANT, NOT DEX-COOL(TM)).
IMPORTANT: WHEN USING A GMDE WATERLESS COOLANT CHANGER, CONDUCT THE PROCEDURE TWICE, ONCE WITH WATER, AND ONCE WITH DEX-COOL(TM).
BACKSERVICE WITH DEX-COOL(TM) IS ADVOCATED BECAUSE OF ENHANCED WATER PUMP SEAL DURABILITY EXPERIENCED WITH THIS COOLANT.
no other mention of pellets in 92-96 y-body cars it the tsb search.
95 was the first year for dex-cool and some 95 c4s were mislabled needing a sticker change through a campaign.
thats iteresting input they sent out on the benefits of dex-cool.sounds like a good idea to use it.just make darn sure you get a good flush.one notice i read said dex-cool can be contaminated by the green stuff by merely using the same pour can.
sorry about the length of this post fellas
that is if your just gonna flush it yourself with some coolant flush and a hose.
the other option,and maybe best,is if you can hire someone with a flushing machine that you trust to do a thorough job and double flush it for a switch to dex-cool like gm recommended.
and then i would still add a couple pellets.
take your time.drain the system,refill it with water.warm it up,let it cool,drain the system...repeat.probly not a good idea on our engines to run it with cold water running through it.just use the fill,circulate,drain,refill method being careful not to add cold water to a warm block.
use the air purge valves at the front of the intake to get all the air out too.
i would figure on it being a good 12 pack job for 2 guys.
