Emission Testing
Old Oct 13, 2004 | 02:24 PM
Snoozer's Avatar
Snoozer
Default Emission Testing
I need some advice - I took my 94 in for emission testing and did not pass the HC test. Off by about .1. Took car to deliever and they checked everything out and found not codes for any problems and could not find any reason for not passing test. Took car back for retest and it still failed. Deliever said that it had to be the Catalyic Converters and that eventhough they did not test bad, that I should change them. Cost $2200. I did not do it, but read in the 101 projects for my corvette that the changing of the Cat. Conv was not a big deal and that it is done by dropping the exhaust system. Questions, have any of you had emmision problems, is it related to Cat. Conv? How offen do they go bad (I have 70,000 miles on car)? What if I change the O2 sensors (even though dealer did not seem to think that would help). Also where can I buy Cat. Conv. if I need them and do this myself? Sorry for all the questions - I don't want to spend $2200.
Snoozer
Old Oct 13, 2004 | 03:02 PM
mikey whipreck's Avatar
mikey whipreck
2200 for replacing the Cat?!
I know you have an lt1/4 and the setup is different then my l98... For starters you have two cats i believe...
anyway, on my l98, it took about half an hour to get my cat off, and another half hour to put it back on. I did not have to drop the exhaust at all...
I should really let the lt1/4 owners speak up though, how hard is it guys?
Old Oct 13, 2004 | 03:14 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Changing the cats isn't hard.......once you get past the rusted bolts and hopefully not breaking any of them.
I've seen used ones going from $50-$300 for a pair.
Random Tech makes direct replacements but I haven't been able to find them on the net, saw it in a magazine, and I don't know the cost.
Old Oct 13, 2004 | 03:37 PM
VenkmanP's Avatar
VenkmanP
Get a second opinion first.
If the cats really are dead at 10yrs and 70k then you have other problems that killed them. In that case, you don't want to put new cats on until you are sure the rest is working right.
Old Oct 13, 2004 | 05:42 PM
-=Iron Mike=-'s Avatar
-=Iron Mike=-
From what I understand (I failed also) an indicator of bad cat (s) is a high NO level, not HC. I had very high NO levels and I KNOW I have at least one bad cat. I'd get a second opinion as mentioned.
Old Oct 13, 2004 | 05:47 PM
DieL's Avatar
DieL
i just pay $150 and they stick a beater on the machine. just call in the vin and pick up the papers half an hour later
Old Oct 13, 2004 | 05:51 PM
-=Iron Mike=-
around our parts it gives us 12 months of relief.......in the pocket book. BTW who do you know?, my guy won't help me like that.
I guess either way I'll have to fix the sheit eventually.
Old Oct 13, 2004 | 06:10 PM
bmalec's Avatar
bmalec
The converters have a reduction and an oxidation section, according to page #2 of this link NOx is processed in the reduction section and HC in the oxidation section: http://www.meca.org/jahia/Jahia/engi...d&fileItem=251 .
So, it's possible the reduction section is working ok, but the oxidation section isn't. I don't have an LT1, but I'd venture to guess that possibly your AIR pump isn't working correctly (also there should be a line from the AIR pump to the converter, maybe that's not sending air correctly?) or maybe it's just running too rich (or misfiring) and the converter can't process the excess HC?
How do your plugs look?
Ben
Old Oct 13, 2004 | 06:39 PM
Getzen88's Avatar
Getzen88
i'm probably wrong, but i thought HC was unburned fuel...so i would look at leaky injectors or a valve not opening/closing all the way. just my ideas...
Mike
Old Oct 13, 2004 | 06:43 PM
bmalec's Avatar
bmalec
You're correct, HC is unburnt fuel.
Ben
Old Oct 13, 2004 | 09:15 PM
Snoozer's Avatar
Snoozer
Default emissions
Ben
Thanks for all the replies. I will have to get another opinion. What baffels me, is that the dealer could not find anything wrong with how the engine is running. I would have thought that is the air pump or others things were not working, they would have found it.
I will check later for other replies.
Snoozer
Old Oct 14, 2004 | 10:43 PM
redwing76's Avatar
redwing76
Snoozer
What we do here is a pre-test. Thats a test without the local gov hookup.
When the machine is hooked to the car (ie piped) the machine is in contact with the local dept of motor vehicles. If you don't pass the DMV flags the test. They keep a record.
To do a pre-test the machine checks the car emissions without the dmv knowing about it. That way if you fail its not recorded.
HC hydrocarbons is as stated earlier un-burned gasoline.
A good tune good go along ways here. Also have the car tested with a diagnostic computer to check for a failed cat or 02 sensor.
It is possible that a bad or malfunctiong MAS could be at fault.
Theres a myriad of problems that could cause a bad reading.
PLugs, injectors, mas, cat, I've seen them all cause a bad test.
A diagnostic computer is the fastest way to finding the problem.
Some tune-up shops guarentee a pass.
Good luck.
Old Oct 14, 2004 | 11:17 PM
bobmic93's Avatar
bobmic93
The temperature of your cars engine could be the problem with passing the hc test. If you have 160 stat the engine is not hot enough to burn off all the hc's. Put the stock stat back in for the test and youll pass. This happened to me
To Emission Testing
