Security question from a newbie
), which was a theft / recovery and t has the horns disconnected. I thought it was a result of the theft but the more I find out the more I think it is because the security system was always going off all of the time. Here is what I know (if you think this is not acturate let me know).1. When I get in the car there is a clicking noise. I am assuming this is the security trying to blow the horns which are disconnected.
2. I have found that I can turn the clicking noise off by unlocking the passenger door with the key. Note: unlocking the driver door and starting the car does not turn off the clicking noise.
I think there is a problem in the locking mechanism of the driver door. Not sure if the ignition should turn it off or not.
My question: Does anyone know how the security system is armed and disarmed and what I should look for with the driver side not working? I would be doing the work myself assuming no special equipment is needed.
Thanks in advance,
Jim
Mike
:The alarm should be disabled by unlocking the driver's side door with the key. Sounds like some bad wiring in the door. However, I could be wrong. I'm just going by how my '85's alarm works.
Good luck!
Thanks for the welcome... I guess I am goint to have to get someone to help with testing the wiring. I wasn't sure if there was some kind of switch that may have just gone bad, etc.
Man I love this car. It is a red convertible... I call it c4.5 because it has the C5 body upgrade. I also have a pure white 89 C4 that I am putting together... I was going to sell it but now I seriously considering keeping it also and restoring 100% C4.
Thanks for the quick response
