Hood Emblem Question
Old Oct 23, 2004 | 11:15 PM
Chewch87's Avatar
Chewch87
Default Hood Emblem Question
I replaced the rear gas door emblem.....hair dryer and dental floss......easy enough.
Before I scratch up anything, is the hood emblem held on by just adhesive or is it also bolted on like the gas door emblem?
Old Oct 24, 2004 | 12:47 AM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
If my memory serves me correct they are also held on by 10mm speed nuts. Use some grease on your deep well socket or one with a magnet as they fall off easily. They then slide from side to side inside the lip everytime you turn a corner!
Old Oct 24, 2004 | 12:54 AM
MrRenoman's Avatar
MrRenoman
Masking tape works good too.
Old Oct 24, 2004 | 02:32 AM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
grease, or the masking tape thing works too to hold the nuts into sockett. If you havent located them yet , raise your hood and look just under the "BOWLING GREEN" emblem and you'll see the two holes that access the nuts. If you're working alone it may be a good idea to put a bit of tape on the emblem itself as paint safegaurd so emblem cant fall loose when you remove nuts.
Old Oct 24, 2004 | 02:35 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
-JRC-
Old Oct 26, 2004 | 12:20 AM
Dads90's Avatar
Dads90
I actually used a small drop of crazy glue on the socket side , placed it thru the hole, once on the nut, counted to ten, then removed them. Once it was time to replace them I wobbled the socket once they were tight and the socket came right off of the nut. No lost nut. JUST A SMALL DROP. Basically to keep the nut from falling.
Old Oct 26, 2004 | 08:42 AM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
No adhesive - just speed nuts. The grease, masking tape, or glue suggestion(s) is a good one.
Did this myself a couple weeks ago; really helped the front of the 1985.
To Hood Emblem Question
