Arm Rest Reinforcement
Old Oct 23, 2004 | 11:28 PM
reidry's Avatar
reidry
Default Arm Rest Reinforcement
One of my winter project is changing the door panels on my '85. I've seen these arm rest reinforcements in a couple of the catalogs but I've seen no discussion here.
With new panels are the reinforcements necessary? Do they work? Should I add them when installing my new panels this winter?
Thanks,
Ryan
Old Oct 23, 2004 | 11:35 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Originally Posted by reidry
One of my winter project is changing the door panels on my '85. I've seen these arm rest reinforcements in a couple of the catalogs but I've seen no discussion here. With new panels are the reinforcements necessary? Do they work? Should I add them when installing my new panels this winter?
Are you refering to the grab handle reinforments? If so, Yes! The plastic panel will not hold up as well as a little steel.
-JRC-
Old Oct 24, 2004 | 05:39 AM
vetteseniorcit's Avatar
vetteseniorcit
Ryan, I installed these in my 87 and was very satisfied with the solid feel when I pulled my doors closed. I replaced the driver's side door panel and at the same time, installed the inserts. They simply screw into the door's steel frame at the bottom of the pull well. Cheap insurance to keep your panels from separating.
Old Oct 24, 2004 | 10:51 AM
DRAKEFAMILY2's Avatar
DRAKEFAMILY2
I bought a set and am getting ready to install, can't hurt.
Old Oct 24, 2004 | 01:45 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Yes, they are very useful. The fit wasn't perfect, and the holes were off a little, but they worked.
The problem is, when you pull the door shut, you're just pulling on the inner door panel (which is $$ when it falls apart). With these you're actually pulling on the door structure itself.
Old Oct 24, 2004 | 02:38 PM
1Patriot's Avatar
1Patriot
Worth the money and effort. Had them on my 88 coupe for 125k miles. Panels stayed very tight.
Old Oct 24, 2004 | 02:43 PM
Z51JEFF's Avatar
Z51JEFF
I bought a set,didnt fit with the aftermarket crap arm rest and door panel so I reinforced the arm rest from underneath with a piece of 1/8 ABS plastic.Works for me.
Old Oct 25, 2004 | 10:16 AM
tacblu's Avatar
tacblu
How do the door pulls attach? Do you have to make any modifications to the door panel? How about the appearance?
Old Oct 25, 2004 | 10:59 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Very solid feel. Easy install. Saves from problems later.
www.corvettecentral..com
Old Oct 25, 2004 | 01:17 PM
DRAKEFAMILY2
They fit down in the pocket where you put your fingers to close door, two screws.
Old Oct 25, 2004 | 09:37 PM
CentralCoaster
Actually, I wrote up and submitted a tech tip for this a loooong time ago, 2 years ago. I haven't seen it since. If you can't find it in the tech tips section, then you might wanna check with the mods and see where that black hole leads to.
To Arm Rest Reinforcement
