Cooling fan Troubles.
Old Oct 24, 2004 | 12:23 AM
shribe's Avatar
shribe
Default Cooling fan Troubles.
I noticed my primary cooling fan was not working. Switched the plugs at the relays, and had the secondary fan working with A/C on from both relays. I replaced the primary, and started the car to make sure it was working. Primary ran, but the secondary did not come on. Switched relays, same deal. Now the primary would run, but not the secondary. I jumped the terminals on the ALDL, and both fans came on. But neither temp, or turning the A/C on will turn on the secondary fan on now.
Anyone seen this before?
Old Oct 24, 2004 | 12:49 AM
creegs's Avatar
creegs
What year is your car? I had a similar problem and it turned out to be a fuse. Second from the top on the right side, labeled gauges. I had replaced the relays and then was told about this.
Old Oct 24, 2004 | 01:03 AM
mitymek's Avatar
mitymek
the temp switch doesnt kick it on until its pretty hot.something like 210 deg i think.
is your car overheating?
Old Oct 24, 2004 | 01:46 AM
shribe's Avatar
shribe
It's a 92.
It got warm in traffic, but almost did what it was supposed to do. Primary did'nt kick on, but secondary took over from about 230 and took it down to 215. That's when I first checked, and found the primary did not work.
It can't be a fuse, because when I jumped pins a and b, both fans turned on. Before I replaced the primary, only the secondary would come on. Now, the secondary just wont come on with A/C on, or hitting the temp (228* I think), but does come on when I jump the pins.
Old Oct 24, 2004 | 02:17 AM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
Ok I'm pretty well confused now. It's the whole "they both run when jumping the aldl pins a to b" that make me know the fans/relays/fuse/fusible links are good but why only "one working" when AC is on now??, that should have them both on via the AC high pressure switch?? hmmm, strange! Its almost like an ECM thing, or the command from AC hp switch or temp switch is not being recieved by ECM for one fan, because jumping the pins on aldl proves the ECM output still has the ability to ground the relays and run the fans. I dunno Definetly a stickler.
I wrote a tech tip about testing relays and wiring a manual switch that may help you understand things a bit better and help you solve the problem. At least you can wire a manual switch if needed. Here it is. Hope it's at least a little help.
https://www.corvetteforum.com/techti...=282&TopicID=2
Old Oct 24, 2004 | 02:43 AM
shribe's Avatar
shribe
Thanks Dave,
A weird one ain't it. I agree with the ECM thing, but how could have that changed? It allowed the secondary to come on when the primary was inop, but won't tell it to come on now that the primary is working.
The part that really has me confused is the fact that:
When the fan motor was bad, I could swap the plugs at the relay, and the secondary fan would come on hooked to either relay--proved motor was bad on primary.
Now, if it was an ecm problem, Primary fan is running, I swap plugs and plug secondary fan into primary relay, the secondary fan shoud come on because the ecm would think it's plugged into primary fan. It can't tell the difference. I would assume a bad motor, but that's not right, because the secondary will turn on if I jump the pins on the ALDL.
Maybe I'd be better off wiring the secondary to a toggle switch anyway. I'd still have the primary as a safety if the car got warm, and I forgot to turn the toggle switch on.
Very, very strange.
Old Oct 24, 2004 | 02:54 AM
skateparkdave
Originally Posted by shribe
Thanks Dave,
Your welcome, yep thats a gremlin for sure. Yeah, I'd wire a manual regardless as a safegaurd, but definetly if you cant find your trouble.
Good luck
To Cooling fan Troubles.
By Michael S. Palmer | 2026-06-03 09:39:05
