Halloween Bitten
Old Nov 2, 2004 | 01:51 PM
Justardnck's Avatar
Justardnck
Originally Posted by JackRandom
Ahhh, He's so cute! I bet he'd gladly rip someone's arm off for ya!
He used to be 140#s before his wife died, but he lost alittle weight. Still mean as a Junk Yard Dog if you mess with him or his new Condo (my vette). Its the look he gives you when you are where you are not supposed to be that scares people, normally he is as friendly as a poodle.... mess with the property and reep the WIRLWIND!
Old Nov 3, 2004 | 05:42 PM
redvtt's Avatar
redvtt
From: All great change begins at the dinner table Ronald Reagan
Originally Posted by longhorn_C4
Good luck trying to find a Dayton Daytona tire. I searched on tirerack.com and didnt even see the brand name Dayton. Anyone know where our brother here can find them?
I did find one, mine went flat on me, disintegrated the sidewalls. It cost me about $125.00 w/mount & (lousy) balance at a Firestone tire store. Bridgestone makes them [calls them a Dayton] I believe, that might help you in your area. I bought mine late spring. At that time, it wasn't discontinued. Try a Google on Dayton Daytona & it'll come up, that's how I did my research.
Old Nov 3, 2004 | 05:48 PM
redvtt's Avatar
redvtt
Originally Posted by John Robinson
1. If the rim damaged one tire what are the odds that the other three may have been damaged and will give you trouble a few days later
Also, I filed my rim, 1st with a medium file to knock down high ridges, 2nd file was fine, to smooth out and flatten the craters left. Mine hit pavement when the carcass took off into the guardrail.
I fielt the same thing, a little loose, no problem. The Wife kept saying something was wrong, pull over. I thought it was the road, until the carcass took off.
Old Nov 3, 2004 | 06:11 PM
bogus's Avatar
bogus
replace all 4. the sidewalls were compromised. Sad to say.
Dayton tires? ick. I am not a fan.
www.tirerack.com, and check out Kumho.
Old Nov 6, 2004 | 09:59 PM
Tracker's Avatar
Tracker
Thanks all for your help. I did find a dealer that had one tire left. I should get it UPS in a couple of days.
Mike
Old Nov 6, 2004 | 10:24 PM
midlifecrisis91's Avatar
midlifecrisis91
St. Jude Donor '03-'05-'06
Someday it will happen to them. Vandalism Sucks. Hope you get the punks.
Old Nov 7, 2004 | 04:19 AM
comp's Avatar
comp
Mike
cool
Old Nov 7, 2004 | 09:45 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
That suks. Since those tires have been "damaged" by being run flat, You should really replace all four. The sidewall brusing will never repair itself and to drive those tires over 45 is asking for trouble. IMHO
