Shocks are leaking.
Old Nov 3, 2004 | 08:45 PM
94Polo6Speed's Avatar
94Polo6Speed
Default Shocks are leaking.
We noitced while at DRM that one of my rear shocks is leaking pretty bad. They mentioned it was much cheaper, since i have selective ride, to have them rebuilt. Is Bilstien the only company that can do it? What are the chances i have a local company that does it. Never had to do this so i'm at a loss.
Old Nov 3, 2004 | 08:53 PM
c4cruiser's Avatar
c4cruiser
Not sure if anyone other than Bilstein can rebuild their shocks. Another company would have to have access to Bilstein parts. DRM could do the work but I would think they would simply send it off for you.
How bad is the leak? A very light film of oil on the shock is normal. Bilstein add more oil than is needed so seepage is common. If the shock tube is soaking wet with oil, then it should be sent to Bilstein for rebuild. Figure around $100 if the shock rod does not have to be replaced.
Old Nov 3, 2004 | 08:57 PM
94Polo6Speed
Left rear is pretty much blown. I'm putting away soon for winter so i'll pull all 4 and send them in.
Thanks.
To Shocks are leaking.
