Problem w/ 95 Headlight Motor
Old Nov 6, 2004 | 12:24 PM
DavidR14's Avatar
DavidR14
Navigator
Default Problem w/ 95 Headlight Motor
Does anyone have any suggestions on replacing a 95 headlamp motor...I live in Oklahoma City and the dealerships want $500 for one and none of the local part stores have them.....What do you think my best option would be
Old Nov 6, 2004 | 01:35 PM
Z-07 freak's Avatar
Z-07 freak
From: Why are there squished peanut butter cups in my underware?
Chances are the headlight motor is ok, and the problem is the nylon bushings have disintegrated.
Old Nov 6, 2004 | 02:04 PM
CMYC4GO's Avatar
CMYC4GO
Call Corvette Clinic on S. Shields. He's pretty good, and reasonable too.
Also, Vette2Vette is really reasonable.
If you need any more info, feel free to call me. 850-4323
Old Nov 6, 2004 | 04:11 PM
John Robinson's Avatar
John Robinson
Default Fix it yourself
There is probable at least 1 posting in the archives on how to fix the motor yourself. If not this forum will help you do it. I say this because when looking at Mid America Motorworks or other catalogs on the C4 I see they all have the bushings and replacement gears for your headlight motor. Without knowing what all you need I'd still bet you wouldn't have $100 in it if you bought all the parts available used what you needed and stored the rest untill next time This off course assumes you are able to do some work yourself. Like opening a can of beans Good Luck and let us know what you did that's how we learn. :
Old Nov 8, 2004 | 11:12 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Order the bushings from Mid America Motorworks (MAM) or Eckler's ($10) and do the labor yourself. It's really not too hard at all, takes the better part of a Saturday or Sunday...
Here are the installation instructions...
http://www.corvettefever.com/howto/33098/
Old Nov 8, 2004 | 11:53 AM
joecaver's Avatar
joecaver
From: 63.8% of all statistics are made up on the spot.
St. Jude Donor '08-'10
be sure it's the motor first of all. It's rare that it is. As others have said it is usually the bushings that go bad not the motor.
Old Nov 8, 2004 | 02:58 PM
Blue260's Avatar
Blue260
David, follow the link posted by "ONEDEF92", I just replaced the passenger side with nylon bushings purchased from Mid America. At $4.95 it is the least and best possible fix for your time and money. The job took me about 2 hours taking my time and, get this now, without any hitches. Smoooooth!
Hope your job goes as easy as mine.
chris
To Problem w/ 95 Headlight Motor
