maintenance
Old Nov 7, 2004 | 11:22 AM
dm1948's Avatar
dm1948
Default maintenance
i have a 89 with 50,000 miles it runs perfect and i want to keep it that
way. things i have done new tires,brakes, rotors,replaced the mass air
sensor,cleaned the idle air control valve, major tune up,replaced the
intake gaskets can not stand oil leaks getting ready to replace the
surpintine belt is there any other things i should be doing?
thanks
Old Nov 7, 2004 | 01:57 PM
JB666's Avatar
JB666
Looks like you have things under control - You mentioned "major tune-up" , which I'm sure included a gas filter?
Have you flushed your entire cooling system?
Old Nov 7, 2004 | 02:20 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Did you flush the brake fluid and replace it with fresh? Good idea that I still need to do.
Old Nov 7, 2004 | 02:50 PM
John Robinson's Avatar
John Robinson
Default Yes
How about driving it
Old Nov 7, 2004 | 05:18 PM
dm1948's Avatar
dm1948
good one
Old Nov 7, 2004 | 05:19 PM
dm1948's Avatar
dm1948
yes at 32,000
Old Nov 7, 2004 | 05:21 PM
dm1948's Avatar
dm1948
thanks for the help
Old Nov 7, 2004 | 09:37 PM
stick91's Avatar
stick91
Three things I've done recently were not on your list:
Differential fluid replaced
Throttle body cleaned
Power steering fluid changed
Next on the list for my '87 is suspension (Replace shocks & bushings). I also plan to check ball joints, tie rod ends, links, etc.
I think this type of stuff typically gets overlooked on 15 year old vettes!
Old Nov 8, 2004 | 08:51 AM
runner140*'s Avatar
runner140*
Default Flush all fluids
About six to eight months ago, i flushed all fluids---coolant flush, transmission flush, rear end and power stearing fluid flush and last but not least, flush of the brake fluid. Thats just what I did.
To maintenance
