Shock question.
Old Nov 7, 2004 | 12:23 PM
94Polo6Speed's Avatar
94Polo6Speed
Default Shock question.
I have a 94 LT1 with selective ride. I'm gonna do shocks this winter. I am looking at shox.com but i'm confused. The only selective ride shock they seem to have is for ZR1. My car is not a ZR1 but is selective ride. Which shocks do i need? Go to www.shox.com and search 1994 Corvette.
Thanks, Tim
Old Nov 7, 2004 | 01:28 PM
Oly's Avatar
Oly
I believe the first Corvettes that the selective ride option was offered on were ZR1's. My '92 came with selective ride but I converted over to Bilstein Heavy duty because I wanted a softer ride and the adjustable shock actuators were also bad (4 adj. shocks and 4 actuators = big bucks and I'm cheap). I know you can have the shocks repaired at a substantial savings by Bilstein but I'm not sure the actuators are repairable (help me here guys). I have saved all the components in case the next owner wants to have them repaired and re-install them. I have protected the plug ends on the car so they will not become packed with dirt and other stuff.
Check these guys too.... eshocks.com
Good luck.
Old Nov 7, 2004 | 01:43 PM
94Polo6Speed
How hard is it to convert?
Old Nov 7, 2004 | 03:38 PM
Z-07 freak's Avatar
Z-07 freak
From: Why are there squished peanut butter cups in my underware?
All ZR-1s have the FX-3 SRC adjustible shocks. It's the same FX-3 system that is optional on the base engine Vettes.
`89-`91 FX-3 shocks have 160* of rotation
`92-`95 FX-3 shocks have 90* of rotation
The actuators can be used on any year, but there is a difference between fronts and back actuators.
Old Nov 7, 2004 | 05:50 PM
Oly's Avatar
Oly
It's not difficult at all. I wrapped the plug ends on the car with plastic, duct taped around the plastic wrapping and zip tied them so they wouldn't flop around. I check the fronts every so often to make sure the coverings I put on them are still in place. For the rears, I attached a 12 inch length of wire to the plug end with another zip tie and pushed the loose wire end to the rear inside the frame member. Once you unplug the actuator, you need to make a provision that if you ever do want to reinstall the adjustable shocks (rear), you can easily access the plugs for the rear actuators. The tops of the rear shocks attach to some brackets that insert up inside the frame (when you see them it will make more sense). It took more time to wrap the plugs for the actuators and secure them than it did to actually remove and replace the shocks.
I hope this makes sense and helps.
Old Nov 7, 2004 | 07:07 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Easy.
1. unbolt the old, selective ride shocks.
2. bolt on the new, non-selective ride shocks.
Larry
code5coupe
To Shock question.
