40 below
Old Nov 9, 2004 | 07:25 PM
lt4dogman's Avatar
lt4dogman
Default 40 below
Is "40 Below" compatable with Dex-cool(the orange coolant)?
Old Nov 9, 2004 | 08:21 PM
redwing76's Avatar
redwing76
It depends on the mix. The lower temperature the more anti freeze.
Old Nov 10, 2004 | 02:39 AM
qtcoupe's Avatar
qtcoupe
Default "40 below"
If you mean "40 below" the coolant additive it"s supposed to mix with all antifreeze.However my experience with it was in my streetrod. Within a year after installing it my flocool aluminum waterpump seal went out and the sender for the fan relay was eaten away. I had a sacrificial element in the cooling system so don't think it was electrolisis. I flushed the leaked coolant off the paint right away cause that stuff damages paint.I won't use that product again. A busted hose could cost a paint job
Old Nov 10, 2004 | 06:23 AM
comp's Avatar
comp
why???? a clean , correctly servised system DON'T need water softer yep, also called, watter wetter do you have a dish washer???? Jet-Dry???
Old Nov 10, 2004 | 07:22 AM
lt4dogman's Avatar
lt4dogman
Default thanks
Thanks , thats what I needed to know. I thought maybe here in the hot south that the "40 below" would be a good idea, but I won't take the chance.
Old Nov 10, 2004 | 08:42 AM
runner140*'s Avatar
runner140*
Default Save your money....
If you want to cool down the engine, use a 160 degree Tstat. I guess you get what you pay for. $7.00 will not cool you vette much.
Old Nov 11, 2004 | 01:24 AM
skeet's Avatar
skeet
I had been using Dex-Cool in my 85 for about 8 years at which time I added 40 Below. Before the "40 below" this system was shiney clean (radiator internal cooling fins) within 6 months after adding the "40 Below" my cooling system was totally gummed up with this heavy oil. My 4 other cars that use Dex (all with distilled water) never had any problems and always looked very clean . It has to be the 40 Below as far as I am concerned
Old Nov 11, 2004 | 01:26 PM
comp's Avatar
comp
hadn't heard of it messing up a system
Old Nov 11, 2004 | 05:37 PM
lt4dogman's Avatar
lt4dogman
I called the tech-line number on the can and the guy said it was ok as long as the antifreeze didn't have poly-????(can't remember right now) and Dexcool DID NOT have it. But, I decided to play it safe and stay with just Dexcool.
To 40 below
