Hypertech power programmer?
Old Nov 9, 2004 | 07:30 PM
94Polo6Speed's Avatar
94Polo6Speed
Default Hypertech power programmer?
http://www.zip-products.com/Corvette...1A41D1CBD3E6C0
Worth it or not? I'm tech stupid.
Old Nov 9, 2004 | 08:17 PM
ncsugreywolf's Avatar
ncsugreywolf
I used one on mine...and yes it will probably show a diff on the dyno....but I didn't notice enough of a difference between having it in and running without it.
The biggest thing I did notice about the hypertech was it fried my ECM. It got wet and shorted out..and took my ECM with it.
I recommend no. Just one opinion though!!
P.S. I used the programmer that plugged Between the main harness and the ECM. The one for your link is plug and reprogram...so in essence..I may not have answered your question at all!! Sorry.
Old Nov 9, 2004 | 08:21 PM
byte_me's Avatar
byte_me
Originally Posted by 94Polo6Speed
Well- I used it on my stock 94 LT1 automatic...I bought it used\new here for $150...it firmed up my shift points, and changed the temps the fans come on...I can certainly feel the shift's now...oh, it also changed the rev limiter and top end restrictions. I would say for $150 it was worth it- but $300 is too much for a stock tuned car...now if you had some mod's it may be better...
I did get my $150's worth though...but you having a 6 speed would only get a few little things...it says it adds 31 ft\lbs of torque @ 1500 RPM...all I can say is the shifts are a ton more then stock!
Old Nov 9, 2004 | 10:11 PM
dndrsn's Avatar
dndrsn
You can also reprogram your speedometer if you change gear or tire size .
Old Nov 10, 2004 | 08:12 PM
Lone Ranger's Avatar
Lone Ranger
Definitely not worth it for a 6-speed. The shift firmness ability for autos is a good feature, but their so-called engine power tuning sucks. Some have dyno'd and lost about 3 - 5hp using the Hypedtech tuning.
Old Nov 10, 2004 | 08:23 PM
MinnesotaWhite's Avatar
MinnesotaWhite
BUZZ wrong...
So what you are saying...a canned program expecting stock hardware would do better if you had beefier hardware in the car?
Hypertech's do their thing on PURE stock engines only...because that's what they used when they did the tuning...you put on a set of headers and you need to strap the car on a dyno and custom tune.
I'm running the program right now...on the 1/4 it pulled 1/10th off my times...I can easily run a 13.4 now...13.55 was my best before.
Want the best bang for your buck? Get a adjustable fuel regulator and get it dyno tuned...your pig-rich LT1 would pick up a REAL 10 HP for $500 bucks.
Old Nov 11, 2004 | 09:00 AM
runner140*'s Avatar
runner140*
Default It matters....
It matters what you want it to do. Its great at changing shift points on an automatic. Great for reprograming for a new Tstat temperatures.
Change your speedometer for gear or wheel changes and outside of that?
Old Nov 11, 2004 | 03:52 PM
Lone Ranger
Huh? The PCM will just compensate for any change in fuel pressure and still try to hit either 14.7:1 air/fuel ratio at part throttle, or try to hit the air/fuel ratio contained in the PE tables in the PCM if at WOT. Some of the stock entries in my '95's PE table were in the high 11:1 range, for instance 11.8:1 which may not be optimal (between 12.5:1 and 12.9:1 would in theory be better while remaining safe), but is not that rich.
Old Nov 11, 2004 | 06:46 PM
94Polo6Speed
By dyno tunes he means get it on a dyno and have someone reprogram the computer. DRM does it. I think they get around $450.
To Hypertech power programmer?
