Intake Gaskets
Old Nov 16, 2004 | 09:46 PM
GOOG's Avatar
GOOG
Default Intake Gaskets
Anybody put intake gaskets in their car? Had the car 8 hours when I discovered an anti freeze leak. A simple pressure test showed leak coming from front of r/h head and intake manifold. Took it apart last night, an awful lot of vacuum lines, wires, sensors, and who knows what else! Got manifold and 1 runner back on tonight. Should be back together tomorrow. Seller said nothing about. Is this a common problem? I'm working a 1987 4 speed, convertible. The rest of the car is immaculate!!
Other than the a/f leak the car is not a disappointment.
Old Nov 16, 2004 | 09:57 PM
xlr8nflorida's Avatar
xlr8nflorida
Pretty common even on later LT1's.
Old Nov 16, 2004 | 10:14 PM
kize's Avatar
kize
I just found this same leak on my 86 coupe- at the exact same location as you describe. Oh what fun it is to--------
Old Nov 16, 2004 | 10:18 PM
GOOG's Avatar
GOOG
Default parts are cheap
Parts cost me $30, but the labor is a killer!! But on the bright side, those gaskets should be ok for 17 more years.
Old Nov 17, 2004 | 12:03 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I assume you used the FelPro intake gasket set.
Did you use black RTV to seal the front & rear engine lands against the underside of the intake base and a thin layer around the water passages from the heads?
Did you roughen both the engine lands and the under side of the intake base?
Did you clean the intake base bolts and use Permates #2 on them?
If you did all those things and torqued the base bolts to spec in the proper sequence I strongly suggest that you just walk away for 24hrs (to let the RTV cure and bond to the metals) and then retorque the base before installing the rest of the components.
Old Nov 17, 2004 | 01:42 AM
bogus's Avatar
bogus
I agree with 65Z01.
Another trick is to actually drill dimples into the intake and block. It will mean that the RTV will last a long long time.
One last thing, get different bolts... the Torx bolts are very difficult to retorque once the runners are in place. So use regular hex head bolts. Stainless is recommended.
Once they set up, it's not a bad idea to retorque them in about a week or so...
Old Nov 18, 2004 | 06:28 AM
GOOG's Avatar
GOOG
Default It's back together but...
Idle rolls from 700 to 1800 rpm. I think I have a vacuum leak. Whether it's a line off (has to be a big one) or a line that broke back from where I handled it (lines were very brittle). I'l find it, today I hope!!
Tom
To Intake Gaskets
