5w30 vs 10w30
Old Nov 22, 2004 | 02:48 PM
nato's Avatar
nato
Default 5w30 vs 10w30
Right before I got my c4 I moved to SC so shouldwhat weight oil I use change from when I lived in VA? I had a 92 c4 before my 94 in 1995 I sold the 92 in 1997 but when I had it I used 5w30 but when I went to the track the other night a guy there said 5w30 might be ok but would wear the top end of my cylinders out faster than 10w30 would.
I thought at warm/running temps 5w30 and 10w30 both act like 30 weight oil and it wouldn't matter and when it's cold the 5 acts like 5 weight and the 10 acts like 10 weight so in the summer and all why would it matter which you ran?
Old Nov 22, 2004 | 04:05 PM
MYCoupe's Avatar
MYCoupe
The best advice is to use what the manufacturer recommended and that is 5W30.
You're correct when hot both will have the same viscocity so I'm not really sure what that guy meant by his comment. When cold the 5 will flow a little bit easier. I can see you getting away with 10W30 if you lived in a super hot climate, but it's not really necessary.
Old Nov 22, 2004 | 04:58 PM
wildman378's Avatar
wildman378
Mine has always used 5w30 M1 and I haven't had any issues seems to me like you are saying when hot both are 30 weight so if anything 5w30 is better because the only difference will be the 5w30 will flow better in colder weather.
Old Nov 22, 2004 | 05:37 PM
vetteseniorcit's Avatar
vetteseniorcit
Since most engine wear occurs at start-up, the thinner the oil, the better. The beautiful part of the L98, LT1, etc. is their longevity, and the proper grade of oil plays a very large part in that. Whatever brand of oil one uses, if it is the proper viscosity and changed regularly, these engines will live long and prosper. I had an 87 with 155,00 miles on the clock; never torn down, never suffered component failure and it used less than 1/2 quart between 3,000 mile oil changes. Most of that, I suspect, was from worn valve seals. One more thing, these engines turn over at half the revolutions at speed as engines did with the old 4-speed trannys. This contributes greatly to their long life but there ain't no substutute for regular oil changes of the proper viscosity. It is the contaminants in old oil that can do damage, which is why I never exceed 3,000 miles on an oil change. Then I run what brung me; Mobil 5-30W.
Old Nov 22, 2004 | 07:23 PM
vader86's Avatar
vader86
I would probably stick with the 5w30 during the winter, if youre going to be driving alot.
It can be quite cold in the mornings and at night, but the averages for the next couple months are going to be about 50.
Old Nov 22, 2004 | 08:02 PM
redwing76's Avatar
redwing76
5w testes out at 7wht, and 10 wht tests out at 9wht. You're taking a very small difference, hot or cold.
It won't make any difference.
Old Nov 22, 2004 | 08:11 PM
Bruthish's Avatar
Bruthish
St. Jude Donor '03-'04-'06-'08-'09
INMO...run whatthe manufacturer recommends.
Old Nov 23, 2004 | 12:52 AM
skeet's Avatar
skeet
The manufacturer may recommend 5-30 but their main concern is making money. Since a 5-30 gives slightly better gas mileage their CAFE score is lower and they pay less taxes and government fees.
What makes an oil cover a larger viscosity range (5-30 vs 10-30) is the viscosity modifiers that go into the oil. They replace actual oil with a product ( the modifiers) that do not provide the protection of oil. So really there is less OIL in a 5-30 than a 10-30 and less protection.
There is a lot to consider besides this. If I lived in a very cold climate and did a lot of start ups and little highway driving I might use a 5-30. But it would have to be when the temperatures were 0 degrees and below. Otherwise, I would continue to use the 10-30 I have been using for the least 12 years with no problems. I would never use a 10-40 for the same reason.
Old Nov 23, 2004 | 01:50 AM
chriswtx's Avatar
chriswtx
So what about Mobil 1 15w-50? It gets hot down here(we only see 32* one day a year), plus I drive like a mad man...
I've been using Mobil 1 15w-50 for over 10 years in all my turbo and sports cars. Only the wifes car gets 5w-30
Old Nov 23, 2004 | 08:46 AM
runner140*'s Avatar
runner140*
Default I go with the Generals recommendations
The GM book says to use 5W30 and thats what I use.
Old Nov 23, 2004 | 11:36 AM
Nathan Plemons's Avatar
Nathan Plemons
I run 10w30 in mine. Why? Well I like the green bottle cap on mobil 1 better than the red cap.
Seriously though the multi-grade oils require friction modifiers and such to give them their properties. The bigger split between the viscosity numbers the less "stable" the oil is. I really can't quote any specifics though, go look up and download "The Motor Oil Bible" it's good reading.
Old Nov 23, 2004 | 12:02 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
You are exactly right.
Once they are up to temp, they are (in effect) the same oil.
The 5w just flows slightly better at extremely low temps.
Larry
Old Nov 23, 2004 | 12:11 PM
Scooter 94's Avatar
Scooter 94
Recommended oil is best IMO. Other oils work great too, despite all the misconceptions floating around out there.
Old Nov 23, 2004 | 01:20 PM
redwing76's Avatar
redwing76
Larry
Hey Larry what about 0-30?
Old Nov 23, 2004 | 06:25 PM
redvtt's Avatar
redvtt
From: All great change begins at the dinner table Ronald Reagan
Most wear occurs at startup, that's why the spec is set where it's set, no other reason.
To 5w30 vs 10w30
