pcv question
Old Nov 22, 2004 | 06:22 PM
bdvdvh7's Avatar
bdvdvh7
Default pcv question
dumb question.. while i was looking at diagrams, on my 1995 coupe, are there 2 pcv's required? just wondering... thanks!
Old Nov 22, 2004 | 07:03 PM
Lone Ranger's Avatar
Lone Ranger
No. Only one PCV valvle. It is located on the driver side of the intake manifold and has a short U-shaped hose attached which attaches to the end of the PCV and then to a nipple on the intake behind it. The PCV is fed blow-by gasses from the crankcase through the breather tube that comes off the passenger side valve cover to the rear. This breather tube feeds to the top passenger side of the throttle body. From the throttle body the gasses are run through passages in the throttle body and the intake to where the PCV is plugged in.
