Removing Clearcoat from Wheels
Old Nov 22, 2004 | 07:29 PM
GemVETTE's Avatar
GemVETTE
Default Removing Clearcoat from Wheels
I am in the process of removing the clearcoat and buffing up the wheels on my '89 due to clearcoat peeling and dark stains. So far, this has been a real pain-in-the-butt process using steel wool and wet sandpaper. Any suggestions?
Old Nov 22, 2004 | 07:52 PM
xlr8nflorida's Avatar
xlr8nflorida
Yes, its a nightmare - pay a professional about $550 and they will be like new.
Old Nov 22, 2004 | 07:58 PM
C5VetteLS1's Avatar
C5VetteLS1
St. Jude Donor '06-'07-'08-'09
Paint stripper would be much easier to work with. Clear-coat will strip off just like any other paint would.
Old Nov 22, 2004 | 08:01 PM
Justardnck's Avatar
Justardnck
That may stain or darken the Aluminum. I wouldn't try it.
Old Nov 22, 2004 | 08:16 PM
rlt96vette's Avatar
rlt96vette
Default claer coat removal
air craft remover from any parts store spray works best spray on wiat a few spray off with water hose will not harm wheels i did a set of z28 wheels and they looked great very easy to do also
C5VetteLS1's Avatar
C5VetteLS1
Nah, we've been doing this on aluminum aircraft for the past 15 years with no ill effects. We even polish the aluminum to a high chrome finish after stripping the paint and have no problems whatsoever.
Living proof pictured below!
Old Nov 22, 2004 | 08:20 PM
Justardnck's Avatar
Justardnck
Well as long as you have done it before I guess it will work. I just never done it before and it sounded risky.
Old Nov 22, 2004 | 08:31 PM
C5VetteLS1's Avatar
C5VetteLS1
In testing the various stripping products, we've actually put them on bare, highly polished aluminum, then left them on overnight. The next morning, we've wipe them off and found no dulling or discoloration of any sort. I was actually pretty surprised that the strippers had no effect at all.
Old Nov 22, 2004 | 09:12 PM
Atok's Avatar
Atok
I used TalStrip-2 Aircraft stripper. It took about 5 minutes to strip all the clearcoat and paint from my '95 wheels. It left the wheels VERY clean.
Then the real work starts...To get a mirror finish you must sand all the machining grooves out. I used 360, 400, 600, 1000, 1500 grit wet paper and finished it off with fine cut rubbing compound. All done by hand. The finishing touch was Mother's Billet Metal polish. almost perfect mirror finish.
http://www3.ns.sympatico.ca/krichar/...torage2004.htm
Old Nov 22, 2004 | 09:13 PM
Shore's Avatar
Shore
oxidation is what causes the dulling of bare aluminum.Acid will dull the heck outta them fast!....paint stripper won't do a thing but strip paint.Careful on leaving it on rubber too long ...as in hours not minutes.
Old Nov 22, 2004 | 09:21 PM
Justardnck's Avatar
Justardnck
Man that looks awsome... you got me thinking of not buying ZR1s now. How is the up keep on those now? What did you seal those with?
Old Nov 22, 2004 | 11:06 PM
richdwyer's Avatar
richdwyer
Did the wheels on my 89 last spring. Aircraft stripper works great, you can actually see the clearcoat crackle and lift while brushing it on. Get the jug instead of the aerosol. It's easier and more accurate to apply and much cheaper. Make sure you hose it down good afterwards. Don't forget to remove the plastic inserts in the centercaps before doing them. Still a pain polishing them but well worth the effort when your done. Did mine in two weekends. You can pay to have it done, but I always feel better having done it myself. Good luck and happy polishing.
Old Nov 22, 2004 | 11:29 PM
teebee's Avatar
teebee
2021 C6 of the Year Winner - Unmodified
Justardnck
What do you do with the wheels after you have stripped and polished? Clearcoat again? Or something else?
Is this job (stripping & polishing) easier to do with the tires off or can it be done with the tires on? This looks like a good project over the winter.
Old Nov 22, 2004 | 11:30 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
OK, before we scare the he11 outa this guy.......... I used the water soluable paint stripper found at OSH. Its about 8 bucks a can and should easily do four wheels. After removing the wheels (leave tires on wheels) from the car I let'em sit in the sun and get warm. Then applied a coat of the stripper with a cheap brush and then waited a bit before cleaning off with the garden hose. Reapply as necessary. Once I had the clear off I used a buffing wheel on the drill motor and some Mothers aluminum polish. Start to finish was 6 hours. They look great and will continue to brighten after each polishing.
-JRC-
Old Nov 23, 2004 | 08:34 AM
1stC3Vette's Avatar
1stC3Vette
I started to do one wheel with the aircraft stripper. I then gave up and had them done. They bead blasted them and re-clearcoated them. I could not be happier.
Good luck. Use a good clear coat and take your time. It is well worth the work.
Dino
Old Nov 23, 2004 | 10:00 AM
rbesq's Avatar
rbesq
E-mail sent.
Old Nov 23, 2004 | 12:21 PM
LoneStarSoldier's Avatar
LoneStarSoldier
I used Lacquer Thinner soaked rags on mine and it worked great. Leave them for awhile and then use a green scrub pad to clean it up.
HAVE A GREAT DAY!!!!!!!!!
To Removing Clearcoat from Wheels
Old Nov 23, 2004 | 01:54 PM
Kwikerthanu's Avatar
Kwikerthanu
St. Jude Donor '05-'06
Tal-Strip works best on aluminum, as that is what it is made for. Never have used it on Corvette wheels, but have used it on other aluminum wheels, with remarkable results. I let them warm in the sun, not hot, as this will dry the stripper out. Move them to a nice shady spot, apply the stripper and let it work its magic, doesn't hurt to have your favorite beverage while you wait 10-15 minutes and spray them with the hose. You may have some stubborn spots, so let the wheels warm in the sun again, and reapply. Usually the second or third time they are spotless. This is just my experience, your results may vary. Have fun with your project.
Old Nov 23, 2004 | 02:30 PM
iceman_t1's Avatar
iceman_t1
I followed a similar path as Atok. I used aircraft stripper I got at Autozone and used an old paint brush to apply. Be careful to not get the stripper on the fins of the sawblades that you don't want to remove the clearcoat and paint. I put ductape on the sidewall of the wheel to keep the aluminum dust off the sidewall. I started with 220 sandpaper to get the machine grooves out and sanded all the way up to 2000 grit. I tried the compound and buffing wheel on a scrap piece of aluminum but I never did get the hang of it. I have three wheels finished and one to go. I feel it was worth it and the look I get from people who find out I did it by hand is priceless. I have pics if anybody wants them, just email me.
Atok, email sent regarding fine cut rubbing compound.
Old Nov 23, 2004 | 02:50 PM
Southern Comfort's Avatar
Southern Comfort
I am not sure what the USAF uses now but the Thunderbirds used to use metal polish mixed with flour.
