What's wrong with the 84's?
Old Nov 25, 2004 | 07:58 PM
crall013's Avatar
crall013
5th Gear
Default What's wrong with the 84's?
I'm currently looking to buy my first vette. I've wanted one for years and finally some money to get one. I'm still in college so I'm looking for a used one. I have found a lot of 84's cheap in my area (st. louis). Starting around $3500. I've noticed that they are cheaper then the other years. What I'm wanting to know is if there's some reason why they are so cheap compared to the others. Is there something I should know about 'em, or should I jump on this chance?
Old Nov 25, 2004 | 07:59 PM
Shore's Avatar
Shore
Well for starters they were the dogs.........like 200hp.
Old Nov 25, 2004 | 08:10 PM
tonymax2's Avatar
tonymax2
Get a copy of Mike Antonicks' Cor-Vette Specs, ISBN0-933534-51-5 (library maybe) and read it at least once-then you'll know. Then read as many of the posts on this site as possible to get an idea of what you'll be getting into money-wise after the buy. Then decide if you want a C4 (or any 'vette for that matter!!
Old Nov 25, 2004 | 08:11 PM
c4sforever's Avatar
c4sforever
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
it depends on what you want be it manual or auto.they aren't the fastest vettes ever made but they are a cheap platform for so mods.the manual trans is the weak link on the 84 to 88.in particular the overdrive unit.if you want one to mod replace it with a 5 speed.other than that i'm still learning what my 84 can and can't do.btw look for one with the z-51 package you won't be sorry
Old Nov 25, 2004 | 08:13 PM
Jet-Jock's Avatar
Jet-Jock
Being a college student and your first vette I'd say no. Its not that there is anything wrong with them, I'm sure compared to the other later model C4's functionality and usability was much improved. It was first year of a radical new design. It was also born during the gas crisis - polution crisis era.
The question is as a college student will you be able to handle the repairs you'll be faced with? The 3500. may get you the keys but plan on repair costs.
It you want a vette, then I'd look at an 88-90. Unless you can find a deal on a later year model C4. But no matter what year allocate for maintenance costs.
Old Nov 25, 2004 | 08:15 PM
Nathan Plemons's Avatar
Nathan Plemons
The biggest drawback with the 84 is it's engine. It is the best handling C4 period.
The engine was the Cross-Fire injection setup. Commonly referred to as the Misfire, CeaseFire, Backfire, or CatchFire fuel injection system.
From the factory they are pretty lacking in the power department but it's nothing that can't be fixed with the right modifications. If you can find one in good shape in your price range, by all means go for it.
Old Nov 25, 2004 | 08:31 PM
crall013's Avatar
crall013
5th Gear
Default thanks
thanks your comments have helped, I think I save up a little more and get a different year. Better safe then sorry.
Old Nov 25, 2004 | 08:58 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Old Nov 25, 2004 | 10:20 PM
Bruthish's Avatar
Bruthish
St. Jude Donor '03-'04-'06-'08-'09
According to some....since they are now 20 years old, the values are starting to go up a little. Personally, if your asking for opinions, g with the TPI motor...its quick and can be modded easily as the money comes available. Good Luck!
Old Nov 26, 2004 | 09:38 AM
Alcee1's Avatar
Alcee1
Should I say something,,,,,NOT,,,I'll stay out of this...
To What's wrong with the 84's?
