Digi Dash Sunburnt?
Old Dec 3, 2004 | 05:00 AM
Albert C4's Avatar
Albert C4
Default Digi Dash Sunburnt?
My digi dash speedometer looks sunburnt. Is this repairable or do I need a new dash?
I've seen Ecklers and others offer to repair for $300 plus extra for LCD's. Would sunburnt require an LCD replacement?
My tach is fine, could I just replace the speedo, or does the whole dash have to go.
Old Dec 3, 2004 | 12:32 PM
yellowlust's Avatar
yellowlust
Sunburnt?
Any chance you can post a pic?
Old Dec 3, 2004 | 11:33 PM
86_Vette's Avatar
86_Vette
Unfortunately, you will need to replace the LCD's, just the panel that is bad
Old Dec 4, 2004 | 01:35 PM
kize's Avatar
kize
There is a colored ribbon and an lcd which could contribute to your issue. The lcd's are seperate- you can replace individually- finding good ones can be fun.
Old Dec 4, 2004 | 11:09 PM
mikey whipreck's Avatar
mikey whipreck
If it is indeed sunburnt, you will need to replace the LCD panes... The cheapest way would be to find a busted cluster with good LCD's...
otherwise, the added cost of replacing LCD's is painful...
To Digi Dash Sunburnt?
