Trans Flush
if more people changed their tranny fluid as suggested in their owners manual there would be less trans problems in the world.fluid and filter every 30,000
I used a cheapo suction gun and some rubber tubing.
Mobil 1.
On my Scout II...I flush with the following method:
Take an empty gallon jug and mark on the jug approximately where a quart of fluid fills to.
Make sure your tranny fluid is up to level when warm before starting this procedure.
Disconnect the tranny cooler/heater exchanger output line. Hook some rubber tubing from the outlet of the cooler/exchanger into a gallon jug.
Start the engine and let the tranny pump fill up the gallon jug...to the quart mark. Shut off the engine.
Put one quart of fresh fluid into the transmission.
Repeat the start, stop routine until either you have put in your applications full capacity...or the fluid coming out looks new.
Check the level hot in park (or neutral for Scouts!)
This not only gives you a full exchange of fluid, but also doesn't "force" flush debris through your valve body, cooler, etc, like the machines sometimes do.
Now as far as the filter change goes...I suppose you have two choices there as well. I prefer to change the filter after I flush. I think this makes sense only because changing the filter first exposes the new filter to dirty fluid. You do waste more fluid this way; however, I don't mind.
Someday I plan on putting in a drain plug and an aftermarket spin on type filter. This should definitely help with the mess involved.
i followed this procedure when i did mine back in march and it pumps it out much faster than you would think...buy a few more quarts of ATF than you need...i just kept pouring more in and watching the level as it was being pumped out...if you do it fast enough you can add it about as fast as it is being pumped out...i had my dad shut the car down when it got to the right level that I measured and I was about 1 quart behind it so i added the extra fluid, got it at operating temp, let it idle and checked it and everything has been fine since...I also used royal purple max ATF...it is a little more expensive but this is not something that is done very often and I would rather have the extra heat capacity for $60 more.
edit: i would be worried about killing your battery since i believe the vette has around 15 quart capacity, you will be starting and stopping your car 15 times if you do it quart at a time without letting your alternator have sufficient time to recharge your battery
clean red trans oil shouldnt break down and need changed ever really.autos shouldnt see that kind of heat unless somethings failing or severe usage maybe,drag racing or towing....
not that im suggesting dont change it.a fresh filter is always good to get rid of the normal metal particles and new blood certainly isnt going to hurt it any.
tip on pulling the pan-remove the furthest bolts away from yourself first.if your at the rear pull the front row then both sides working towards the rear.when you crack the last row of bolts the pan should start saggin to the front dumping into the drain pan.keep loosening the last bolts as the trans pan sags more...works good.
But to change the filter you have to drop the pan right?
Every AT car I've owned or worked on ATF is a 30-40k maintenance item. And even at 30k the fluid is usually pretty worn out.
to the point im getting at,30k miles is a better safe than sorry thing but its really not a relavent thing to judge trans oil condition by milleage.
if the oil never exceeds 175 deg f then it will last indefinately.if you get you vehicle stuck and are rocking it out,or pulling a heavy load,or even overheat the engine from say a water pump failure and end up heating the trans oil to 200 deg the fluid will oxidize and turn brownish looking and start stinking.
so what if this occurs when your oil only has 1000 miles on it?
your going to drive for 29000 miles varnsihing the internals the whole time.
im just saying that i feel its more important to monitor the conditionn of the oil rather than how many miles is on it.
30k filter change and 2/3 oil is good pm as a general rule.
synthetic oil would eliminate the burning problem as it can take much more heat.
if it ever looks orangeish/brown or doesnt smell right,get it out of there.
and think about a cooler or at least a temp gage for it.
