Build Sticker
Old Dec 16, 2004 | 03:07 PM
vettnatic86's Avatar
vettnatic86
Default Build Sticker
Does anyone have any ideas on how to remove my build sticker from the FRONT of the fuel tank. I'd like to stay away from dropping the tank. I see there is only 1/2 inch of space to work with, so any ideas would be appreciated. Thanks
Old Dec 16, 2004 | 07:34 PM
c4cruiser's Avatar
c4cruiser
The build sheet is pretty much glued down over the length and width of the paper sheet. Dropping the tank is really the best method, unless you want to order a copy from the National Corvette Museum www.corvettemuseum.com. You can get a copy of the window sticker too:
https://www.corvettemuseum.com/libra...ts/index.shtml
Old Dec 16, 2004 | 08:10 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Get one from the museum! You will both benefit
Old Dec 16, 2004 | 08:17 PM
Perfusion's Avatar
Perfusion
Definitely the way I'd go!
Old Dec 17, 2004 | 09:13 AM
vettefast's Avatar
vettefast
Make sure you get it laminated!
Old Dec 17, 2004 | 10:04 AM
Strick's Avatar
Strick
That's what I did and got the lamination along with the window sticker. Nice stuff to display at shows. This is where I found out that I have a very rare dif ratio for a 92 6 speed. RPO GHO which is a 3.54!
To Build Sticker
