Im looking to get new Wheels for my Vette. What is the stock offset of C4 Sawblades. Its it 9.5 all around or 8.5 in the front and 9.5 in the back. I need to know asap cause im about to order some 98 Z06 wheels for my C4 Vert
What year Vette do you have. Since you said Sawblades, I can think you have either a 91 or 92.
The width of the rim is one thing, but it is the offset that you need to worry about with aftermarket rims. I think that the rims for 88 - 96 vettes have a 56mm offset. The rims for 84 -87 have a 36 mm offset. With other people adding to this you will find out if the 56mm offset is correct.
I noticed on some websites they say it is a 53mm offset, but I think the 56mm is correct. A 3mm difference is 1/8 inch.
"98 Z06" wheels?? The Z06 wasn't introduced until 2001.
Standard C5 wheels were 8.5x17 in front and 9.5x18 in the rear. Any standard C5 wheel should fit on 88 thru 96 C4's. Z06-specific wheels were 9.5x17 in front and 10.5x18 in the rear.
