emergency brake problem
Old Dec 21, 2004 | 10:54 PM
Ray z's Avatar
Ray z
Default emergency brake problem
I have a 96 CE. I pull up to engage the emergency brake and the ratcheting mecanism doesnt seem to be working. I read on a previous post to shoot some penetrating liquid to free up the mechanism. If so where do you do this.
If this doensnt work, I quess I must replace the lever itself, how difficult is this.
Ray
Old Dec 22, 2004 | 12:04 AM
LT4play's Avatar
LT4play
Mine sometimes doens't like to set after it sits a while. I sometimes have to pull up on it multiple times (like 5+ times). Does your car tend to sit? Have you tried multiple pulls?
Old Dec 22, 2004 | 01:03 AM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
Try pulling the handle all the way up then push the release button and sort of shift the handle about a bit then push it down while holding button. Sometimes this will free mine up. Sometimes it takes a few attempts. Hope this helps.
To emergency brake problem
