Mold
Old Dec 22, 2004 | 01:20 AM
tonymax2's Avatar
tonymax2
Default Mold
Hey Guys,
While checking out an '89 coupe last week in east central IN, I came across something I hadn't seen before. There was significant mold on the leather of the standard seats where the bolsters overlap the seat cushions. Passenger side was significantly worse than the drivers-makes sense 'cause drivers seat gets used more often which opens up that crevice a bit. Car had 64.000 showing and records show about 1K/year over the last 4 years and 3600 miles/year over the previous 9 years. Parked under a cloth cover in an unheated, 2 car attached, residential, ground level garage, facing west with a 16' overhead sectional door. House was on a 5 acre lot in flat country. Area didn't appear to be abnormally wet. I don't think car has been driven much at all for a year or 2. Otherwise, interior and exterior were good to excellent. Might be something to check on especially for those who don't spank their babies a lot. Just what I needed, one more item on my check list!!
Old Dec 22, 2004 | 01:48 AM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
Yuk! There are many strains of molds but most need 4 to 5 things to make most molds thrive. 1 mosture, 2 darkness, 3 low to no ventilation. 4 usually warm temps and 5 sometimes a protien source.(bread, meat, human debris ect) This car you speak of is being stored improperly and is probably subject to many temp changes causing condensation and lack of ventilation and light are also factors. Probably just needs a good cleaning and to be aired out more often.
Old Dec 22, 2004 | 02:36 AM
VenkmanP's Avatar
VenkmanP
Mold means lots of moisture and that's bad for most parts of the car.
Owner that shows a car with mold on the seats is an owner that doesn't give a rats azz about the car, so there are probably more problems.
I second the "Yuk"
Old Dec 22, 2004 | 07:19 AM
Justardnck's Avatar
Justardnck
I have a buddy here in South Florida that has this same problem. His vette and his supra both sit in a garage usually for a year without being touched and he'll open the cars up and there is always mold. This is not the mold most of you are imagining but it looks more like a discoloration untill its wiped off. Both of his cars sit in a garage uncoverd... I guess the humidity finds its way into everything and then you add no air and sun and you have nice little incubator.
Old Dec 22, 2004 | 10:23 AM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
That is damn near everything a car cover provides. I had this happen to my 78 TA. I had mold on the entire interior. I was told after the fact that the cover should be used in the event that conditions will not be favorable to the finish of the car... ie snow. Otherwise it is not wise to let a car sit under a cover for an extended period of time.
That would have been nice to know before I ruined my $2000 custom interior install. Live and learn I guess.
Old Dec 22, 2004 | 04:54 PM
*89x2*'s Avatar
*89x2*
From: ...tearing up the highways, one state at a time™®©
I keep a dehumidifier in my garage, running all the time
Garage was 85% humid before, 45% now...
Old Dec 22, 2004 | 05:00 PM
Southern Comfort's Avatar
Southern Comfort
great source of protien if you get stranded....
Old Dec 23, 2004 | 05:07 PM
C4Crazy787's Avatar
C4Crazy787
"Thank God I have enough money that" I won't have to set on moldy seats...
Old Dec 23, 2004 | 05:52 PM
*89x2*'s Avatar
*89x2*
it is 95% + humid outside today w/ a cool "feel" to the air - was a bit stickier earlier today...
Garage is "dry feeling" and a constant 54 deg w/ 45% humidity - It is VERY important, as all of our Vettes are targets of mold, etc.
Old Dec 23, 2004 | 07:32 PM
Bruthish's Avatar
Bruthish
St. Jude Donor '03-'04-'06-'08-'09
Stay away
To Mold
