Gauuuuud!!! You got my attention--I'm looking for an '89!
I'd be interested in knowing the actual failure mode. If it failed in torsion from a torque overload, the fracture area will have a 45 degree helically angled surface form. If it failed by bending fatigue, you should see a basically flat progressive area of "shiney" metal, perhaps with an obviously rusted or weathered area where a crack started on the OD, followed by the final torsion failue with it's characteristic 45 degree final break. Hardness testing and microstructure examination would also be appropriate to get a good idea of the primary cause. Close-up pics would be good. If you like, let me know and I'll send you the shipping money to send it to me. If so, try not to mechanically damage the broken surfaces. Do you know if that's a GM original or an aftermarket unit? Sure hope that was a fluke!!
I never liked those "packaged" bearings--I've been toying with the idea of converting them to the old standard "Timken" style that last forever with a little care. That's way down the road though, gotta get the car first!
Reason: spelling and add question
Front what I can tell it my have a few stress cracks. Very hard to see. The break is almost a 45 degree angle but the wheel part is concave slighly and the hub part is convex. The center looks like its been snapped. not smooth as the outter.
My thoughts on this was to buy 2 new hubs today after I took the front apart.
No rust marks.
I got this hub from Rockauto.com or Katco (Parts House). They use the same parts.
I would also like to know what caused this. Im thinking it was a bad casting or metal compounds.
If you want me to send it let me know where is going.
My roommate saw my hub and went with me to the autoparts store. He bought 2 hubs for his WS6
