Door ajar "idiot light"
Old Dec 28, 2004 | 07:40 PM
navyy8's Avatar
navyy8
6th Gear
Default Door ajar "idiot light"
Driver side door on my 90 will not close properly. I get the "door ajar" idiot light come on. BTW, The temp outside in the morning is 20s-high teens. Any solutions. Times like this I wish I lived in Florida.
Old Dec 28, 2004 | 07:46 PM
94newyork's Avatar
94newyork
why dosent it close? what dose it do? can you lift the door up and down?
Old Dec 28, 2004 | 07:47 PM
drvn2fast's Avatar
drvn2fast
sounds like you need to adjust your door
Old Dec 28, 2004 | 08:05 PM
navyy8's Avatar
navyy8
6th Gear
I think the extreme cold weather has something to do with it. The door will close properly after driving for 35 minutes.
Old Dec 28, 2004 | 08:13 PM
ZRWON's Avatar
ZRWON
Does interior light also stay lit? If so, try pushing button to see if it goes out. If so put some small pieces of tape on black plastic button on the door frame to build it up to point where light goes off when door is closed and switch is pushed in farther. I experimented with 3 or 4 tape pieces over the button until I got it to work.
Old Dec 28, 2004 | 08:20 PM
twkeough's Avatar
twkeough
I had that problem it turned out that one of the torque screws had become loose on the latching mechanism
Old Dec 28, 2004 | 10:23 PM
94newyork's Avatar
94newyork
with all
Old Dec 29, 2004 | 11:12 AM
RIISITAS's Avatar
RIISITAS
I find it curious that you can close the door properly after 35 minutes. Do you mean the light goes off after 35 minutes? Cold weather by itself shouldn't affect it very much.
To Door ajar "idiot light"
