Starter?
Old Dec 30, 2004 | 07:14 PM
Yellow95's Avatar
Yellow95
Default Starter?
The ole '95 with 108k miles is starting to refuse to start. When you turn the key it makes a noise like the solinoid but can't seem to crank. Try it a couple of times and it eventually crankes and starts. I cleaned the battery cables but that didn't help.
In my older car it would be the starter. In this one with the VATS I'm not too sure.
Opinions? Is it going to be a beer and cash weekend to start the new year?
Old Dec 30, 2004 | 07:19 PM
Justardnck's Avatar
Justardnck
When the Vats acts up you will hear nothing when trying to start. It sounds like you need a $350.00 starter my friend. Of coarse you need to do some diag first but I think in the end it will be a starter.
fsr402's Avatar
fsr402
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
The starter is not hard to get at. Pull it out and have it tested. My guess is that it's going and will need to be replaced.
Old Dec 30, 2004 | 08:10 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Irvine, CA.
Whoa!
Old Dec 30, 2004 | 08:17 PM
mikey whipreck's Avatar
mikey whipreck
Originally Posted by Justardnck
a $350.00 starter
WHAT?!
for my '85 it cost 34.99 with a lifetime warranty...
Old Dec 30, 2004 | 08:22 PM
anieves's Avatar
anieves
this price is outrageous, for my 85 too, cost less than $40.00 lifetime.
Old Dec 30, 2004 | 08:27 PM
Justardnck's Avatar
Justardnck
Originally Posted by mikey whipreck
WHAT?!
Well you guys have the typical chevy 5.7 starter. The LT1s have a special High Torque starter... check it out on parts direct... I don't know how much they want for the LT1 starter but local dealers around here wanted $350 for it.
Old Dec 30, 2004 | 09:12 PM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
I had mine repaired by a good alternator/starter repair shop for like $60. The later C4's do have a more exspensive high tourqe starter. Look into a rebuild/repair. That way you just stick it back in without the hassle of shimming up a new one. Plus you save cash!
Old Dec 30, 2004 | 10:27 PM
mitymek's Avatar
mitymek
yep (place funky working i agree emoticon here),have it freshened up.mainly just needs a solenoid.
loosen and retighten the batt cables at the batt,the starter and the ground first to make sure its not a bad connection before anything though.
Old Dec 30, 2004 | 10:33 PM
Sandy S's Avatar
Sandy S
Check the cables at the starter end also.
Mine had a loose connection on the wire that activates the solenoid. I found it when I was putting the new really expensive high torque starter in. I now have a new starter anyway.
Old Dec 30, 2004 | 11:02 PM
Yellow95's Avatar
Yellow95
$200 rebuilt at Kragen. Takes a few days to get one.
We need an smilie/frownie with $$$$$. It might get worn out though.
Huntington Beach, DUDE!!
Old Dec 30, 2004 | 11:26 PM
Justardnck's Avatar
Justardnck
I told ya... the later C4s have high torque starters.... they are expensive
Old Dec 31, 2004 | 12:09 AM
Wayne88's Avatar
Wayne88
Guess they are expensive. Ecklers reman:
1992-96 ACDelco LT1 Or LT4 Starter
Part# 37636
$219.99 EA.
100% Remanufactured
No Core Charge
Old Dec 31, 2004 | 08:30 AM
Justardnck's Avatar
Justardnck
Let me give you a heads up... If the local Chevy dealer sells it to you and installs it... you get a lifetime warranty that includes towing so it may be worth it to you.
I got mine installed at a Buick dealer for $201.00 because I have a buddy who has a buddy that is a service advisor there. You may not get that kind of deal but for around $300-$350 would be the normal price I think.
I feel its worth the extra money to have it installed for 2 reasons
1) you don't have to crawl under the car and do it
2) You get the lifetime warranty.
To Starter?
