Vette spinout in rain
Old Jan 10, 2005 | 02:31 AM
mitymek's Avatar
mitymek
Originally Posted by CentralCoaster
ASR might activate while going sideways, but that doesn't mean it's going to do you any good. It'll only match the forward velocity with the front wheels. Unless it's got some rear wheel steering hidden in there I don't know about.
when it kicks in you regroup.totally.its something to do with the gas pedal pushing on the bottom of your foot that is as effective as slapping you upside the head.
throttle chops,nose tucks,brakes start applying....not to mention the noise it makes.
i think you would have to try really hard to get a c4 to do a 180 with the asr on and working.you might be able to if you whip it hard enough,but you would really have to work at it.and definately have to have bad traction or hard tires.
i really like the asr.except for when i forget to push the go button and try and smoke the tires.thats a lil embarrasing.
Old Jan 10, 2005 | 02:33 AM
tm1995c4-LT1's Avatar
tm1995c4-LT1
Originally Posted by 65Z01
Frank, if you want a real challenge try driving your Vette in snow!
Actually the real deal is to have good tread out back. With DRs on it cannot hook up when you get off the accelerator so indeed it would just keep sliding. But with my GY Eagles on it will slap the side of my head into the side window if I get off it too quickly in a spin, even on wet pavement.
But definitely take the Vette to a good alignment shop to have the rear suspension checked out. If alignment changed much you may have bent parts.
Christmas day I was in SC and they got some sleet and snow that evening. I spent two hours playing in it. I had my 95 in a full 4 wheel drift, and fishtailed it more times than I could count. Luckily I was in my hometown and knew all the roads really well. I knew where I could play and where I couldn't. Fortunately I also knew the cop who saw me doin a doughnut. It was guy I went to high school with, so he didn't give me a ticket. I had a blast driving in that stuff, but I wouldn't want to do it on a regular basis. Definitely an eye opening experience. I was impressed at how well the ASR worked (when I had it on). I was somewhat scared of how the ABS worked to, but then again on icy roads even the most advanced ABS system in the world won't help you that much.
Sorry to hear about your wheel. Lets all hope that it was only the wheel that was damaged. Get it checked out. Good luck.
Old Jan 10, 2005 | 03:22 AM
BigStig's Avatar
BigStig
Originally Posted by Mr Mojo
You must done more than a tap, I had mine to the floor all day yesterday and no spinouts.
I'd get yer vette into the shop ASAP, I don't think even an 80's Diesel Volkswagen Rabbit could help from spinning out with the throttle on the floor during a rain storm. jk
Old Jan 10, 2005 | 04:58 AM
for yayo's Avatar
for yayo
I have an 84 VW Rabbit at my other house.
Old Jan 10, 2005 | 08:11 AM
PSO3120's Avatar
PSO3120
Originally Posted by for yayo
What should I look for?
Tony
A good driving school?
Old Jan 10, 2005 | 09:03 AM
joecaver's Avatar
joecaver
From: 63.8% of all statistics are made up on the spot.
St. Jude Donor '08-'10
sorry that the car got damaged but it does sound like you hit the gas harder than you would like for us to believe. Get it checked out and be careful out there.
Old Jan 10, 2005 | 09:48 AM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
...So go ahead and tell me i'm just a ****ty driver now.
I am in no way trying to critisize... but I have this very situation happen everytime it rains (and I'm on my way to work). There is a stop sign at the crest of a hill and when it rains my tires are right in the water run off... and the blacktop is more like ice than concrete. Everytime I take off my wheels spin no matter what car I'm in... but I don't stomp on the pedal hard enough to launch it sideways. There is nothing wrong with breaking traction... the key is what you do when it happens. I wouldn't say you are a bad driver... just don't loose it and hit anything.
Old Jan 10, 2005 | 10:42 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Ouch, cold one!
Old Jan 10, 2005 | 11:42 AM
redwing76's Avatar
redwing76
I gotta say I've never had problem with a C-4 in the wet.
Here in the Santa Cruz mountains we average 60" a season with
an 1" per hour. On a really wet day we get 12" in 12 hours.
During a El Nino we get 93" a season.
C-3's are another story. The C-4 in the wet is night and day over the C-3.
Use your ASR.
Old Jan 10, 2005 | 12:05 PM
dizwiz24's Avatar
dizwiz24
I had a near -spin out on a bright sunny day at 25 MPH with new tires on 400 feet from my garage. Car was in 2nd gear and I had about 40% throttle applied as I went around a slight kink in the road (barely even a turn). I dont know whether ASR helped. I wasnt over driving the car or anything. Heres what happened:
When tires are built, a silicone curing bladder release lube is sprayd on the inside of every 20th or so tire. This release agent transfers itself to the tire cure bladder where it remains for 20-30 cures.
These tires I had built specifically for me when I worked for Goodyear in the technical center. Those guys used ridiculuous amounts of bladder release lube for some reason or other. I just had the tires mounted onto rims and had just put the tires/rims on my car.
Moral of the story...
On new tires be careful until you break them in (and wear off that lube!)
When I mentioned 40% throttle, I should have been giving it 10% throttle.
But I had no way of knowing.
Old Jan 10, 2005 | 06:04 PM
PSO3120's Avatar
PSO3120
Yup, that stuff is all kinds of fun on motorcycle tires
Old Jan 10, 2005 | 06:08 PM
VQT88Vette's Avatar
VQT88Vette
Originally Posted by deiaggie
and to the people about not driving in the rain...these cars wont melt
Yeah! but it leaks everywhere Better to let it stay inside when raining so I don't find anymore leaks
Maybe GM knows that a majority of Corvette owner won't drive their cars in the rain so the Vette leaks quality control wasn't a big issue to them
I drove my 88 Corvette almost everyday even in the winter (when the road was clear enough) when I live in PA/NJ. Even took it out to do donuts in the shooping parking lot near home late at night
Old Jan 10, 2005 | 06:16 PM
Otis's Avatar
Otis
"THOU SHALT NOT EXPOSE CORVETTE TO SEVERE WEATHER CONDITIONS"
Old Jan 10, 2005 | 06:42 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Have you been to the plant? They give a thorough leak test.
Old Jan 11, 2005 | 11:37 PM
JA94vette's Avatar
JA94vette
There has been a lot of talk about ASR. How exactly does it work??? Does it rely solely on the wheel speed sensors at the 4 wheels so there is not one (or two) at a completely different speed than the others? I really have no idea...I was just assuming. Also, does ASR/ABS have a separate computer that is located by the module or is it integral to the ECM??
Old Jan 12, 2005 | 12:02 AM
tempest's Avatar
tempest
in general, yes, but it also uses a lateral accelerometer (mine's located just under the radio head unit) for doing some crude slip regulation while turning. modern stability control systems rely on an angular accelerometer rather than a linear one.
it's a separate unit and the ASR/ABS computer is one and the same (called the EBCM). in 92 it is located in a bin just behind the driver's seat... i think it's the same in yours.
Old Jan 12, 2005 | 12:35 PM
redwing76's Avatar
redwing76
English please!
To Vette spinout in rain
Old Jan 12, 2005 | 12:53 PM
tempest's Avatar
tempest
let me reword my second part in easy-to-read bullet points since it does look confusing:
- the ASR/ABS computer is separate from the ECM
- the ASR and ABS computers are the same computer
- the ASR/ABS computer, called the EBCM, is located behind me in a bin
as for my first part of my response, the simple answer is "yes".
let me know if you'd like me to throw out some more 3- or 4- letter acronyms at ya.
Old Jan 12, 2005 | 12:57 PM
Firevette's Avatar
Firevette
Cruise-In X Veteran
Well heres my 2c. I drive my vette, every single day that it rains. It is my only vehicle and of course my daily driver. I have yet to loose controll of the car. I will say however, that I did drive in the rain with near bald tires once. Not just rain, a pretty good downpour, on the freeway. At highway speeds 65+ it was plain scary, car felt like it was "floating". Not something I would like to experience again. My ZR1 rims showed up the next day and needless to say, they got brand new rubber put on them, problem solved.
I will be putting 555R's on the car in the next month,...have to see how that is going to work out.
Old Jan 12, 2005 | 02:02 PM
rick lambert's Avatar
rick lambert
Never rains in Seattle but when the streets get washed the vette gets driven differently-very light on the pedal when acceleration,just gets to squrrely even with good tires. Glad you were'nt hurt.
