help please!
Old Jan 10, 2005 | 07:48 PM
brogden31's Avatar
brogden31
Default help please!
my 85 will be going down the road perfect then all the sudden die. it does this at all speeds. it seems like the fuel pump is going out but in order to start it again you have to keep the paddle to the floor then it smokes like it flooded out. ( no codes)
Old Jan 10, 2005 | 07:54 PM
rlt96vette's Avatar
rlt96vette
maybe i would check the fuel filter first and go from there i am sure some one will come up with somthing.......
Old Jan 11, 2005 | 01:03 AM
bogus's Avatar
bogus
miles? maintenance history?
It could be any number of things...
Old Jan 11, 2005 | 01:25 AM
85 500 horse's Avatar
85 500 horse
As Bogus correctly stated, to have a prayer in narrowing down your problem, you need to state the vehicle's mileage, what kinds of maintenance you have done to it and when and if quality parts were used. Your problem could be so many different things. But you should never need to gas the car to keep it going. That's the job of the computer.
Old Jan 11, 2005 | 02:04 AM
comp's Avatar
comp
could be a bad wire need the info
Old Jan 11, 2005 | 04:04 AM
brogden31's Avatar
brogden31
thanks everyone, I think I found the problem MY mass air flow clip is broke so it wiggled itself loose
To help please!
