GS 'Vert question
Old Jan 11, 2005 | 04:34 PM
C5Jimmy's Avatar
C5Jimmy
Default GS 'Vert question
Does anyone know why in the '96 Grand Sport convertible, the Z51 option was not available, incl. the larger rear tires? Because a convertible wasn't really considereed performance, unlike the coupe, or is there a legitimite reason, engineering wise. Reason I'm asking is because I might put 17x11's on my '92 'vert (like the GS coupe)just want to know if it would be okay.
Old Jan 11, 2005 | 04:40 PM
boceltics17's Avatar
boceltics17
The reason they did not put the 17x11 on the convertible was that they would not fit in the spare tire holder if you had a flat. Simple, but true.
Old Jan 11, 2005 | 04:45 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Well that and it wouldn't fit behind the seats either, the ZR1 and GS coupes(i believe) came with a spare tire bag to store the tire in the hatch area.
Old Jan 11, 2005 | 05:20 PM
GS Diva's Avatar
GS Diva
I own a GS convertible and have no idea why the tires were different, but, as always, I suggest you check with the Grand Sport Registry www.grandsportregistry.com.
Elaine
Old Jan 11, 2005 | 05:55 PM
Z-07 freak's Avatar
Z-07 freak
From: Why are there squished peanut butter cups in my underware?
For the fourth generation, Z-51s ZR-1s and Z-07s were all restricted to coupes. The convertible was more of an afterthought, thus was considered not strong enough to handle optional performance packages.
Old Jan 11, 2005 | 06:19 PM
Skippy's Avatar
Skippy
I must agree with Mojo. On GS's and ZR-1 cars, the rear tires are too large to fit underneath the car, in the carrier. They each have a bag to put your blown tire and rim in. The cargo area has straps in it, to hold the bagged tire and rim down.
Old Jan 11, 2005 | 07:59 PM
SLOWRIDE's Avatar
SLOWRIDE
You should be able to put the wider rims with no problem except for the flat issue.
Old Jan 12, 2005 | 05:17 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
What they said.
Plus....everybody knows that verts are not the performance type.
Larry
code5coupe
Old Jan 12, 2005 | 05:28 PM
C5Jimmy's Avatar
C5Jimmy
I decided to not go with the 11's in the rear anyway. I feel you probably need a Z51 suspension for the car to handle correctly using those wheels. The GS 'verts couldnt get Z51, so I'm just keeping my 17x9.5s all the way around. Car handles good enough, don't need any BS, or headaches for a "cooler" look. I'm keeping what the car was designed with, don't want to upset its balance. I don't drag, or auto-x anyway. Yes, the coupes are more performance, but 'verts are nicer looking! And less common.(JMHO!)
Old Jan 12, 2005 | 09:08 PM
Strick's Avatar
Strick
Ah come on guys, with a few mods like a camber-brace and a cross-bar, the vert is just as stout as any coupe, maybe even firmer.
To GS 'Vert question
