Fuel filter location
Old Jan 12, 2005 | 02:05 PM
94coupe6sp's Avatar
94coupe6sp
Default Fuel filter location
Basic question....where is the fuel filter on my recently purchased 94? In line, in front of the right rear wheel?
Old Jan 12, 2005 | 02:07 PM
Perfusion's Avatar
Perfusion
On my 96, it's inline "behind" the RF wheel... Basically, if you lay down by the R side door and look around, you'll see it. Just follow the fuel lines (under the rocker panel) forward.
Old Jan 12, 2005 | 02:10 PM
Lichen's Avatar
Lichen
The same on my '93
Old Jan 12, 2005 | 02:18 PM
94coupe6sp's Avatar
94coupe6sp
Thank you. Too cold to lie around on the garage floor any more than necessary. Knew I could also save time and get an answer here.
Old Jan 13, 2005 | 04:18 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
Right in line with the front of the passenger side door under the car on the frame rail ,pull fuzz and run engine until stalls then replace filter.
Old Jan 13, 2005 | 09:14 AM
runner140*'s Avatar
runner140*
Default I agree....
Same on mine.
Old Jan 13, 2005 | 07:06 PM
vetteweiser's Avatar
vetteweiser
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'13- '14
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Yup, its on the passenger side behind the front tire.
If you are replacing it, be sure to loosen your gas cap, pull the pump fuse, crank the engine til dry. This helps get gas out of the line. Then, remove the bracket that holds the filter to the car, take off the bottom line connection (careful, gas will spill out). At this point, you can get out from under the car, free up the fuel line from a bracket in the engine compartment, then gently fish the whole line and filter up. Now, at this point, you have clear and easy access to the top connection of the filter. Remove it, install the new one, and reverse process.
One further thing, if your line does not have O-rings in it, be sure to clean the threads of the line and tighten the crap out of it (just not too much) or else it will leak.
Now that I typed all that out, I sure hope you planned on replacing it
To Fuel filter location
