Replaced everything!!
Old Jan 14, 2005 | 09:57 AM
Gooseit's Avatar
Gooseit
Default Replaced everything!!
After reading so many bad things about water pumps leaking and taking out the opti-spark distributor, I decided to go ahead and replace the water pump on my 95, before it started leaking. WELL, one thing lead to another and I ended up changing the water pump, plugs, plug wires, opti-spark distributor, thermostat, and both belt tensioner pulleys. I replaced the radiator and all hoses last year, so hopefully I will be done with her for a while. It took me about twenty hours to do it all.
Goose
Old Jan 14, 2005 | 10:59 AM
Wayne88's Avatar
Wayne88
Sounds like you enjoy working on the Vette
Old Jan 14, 2005 | 11:51 AM
VFR750's Avatar
VFR750
Sounds like you have a heated garage too!
Old Jan 14, 2005 | 12:00 PM
Ibuyvettes's Avatar
Ibuyvettes
Here's when your starter goes out
Old Jan 14, 2005 | 03:23 PM
Yellow95's Avatar
Yellow95
Individually those jobs can take you 50 hours.
Old Jan 14, 2005 | 03:47 PM
Gooseit's Avatar
Gooseit
I did most all of it by my self, but I do have air tools and a heated shop which made the job a whole lot faster.
Old Jan 14, 2005 | 03:51 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Larry
code5coupe
To Replaced everything!!
