Clutch/ZF6 question
Old Jan 16, 2005 | 12:16 PM
91z07's Avatar
91z07
Default Clutch/ZF6 question
When my clutch is released and the transmission is in nuetral, there's a noticeable "gnashing" noise, and when the clutch is engaged the noise stops. This has occurred for some time now, without getting worse. Is this normal?
Old Jan 16, 2005 | 12:20 PM
redwing76's Avatar
redwing76
www.zfdoc.com see faq.
Old Jan 16, 2005 | 12:37 PM
Red Tornado's Avatar
Red Tornado
91z07, you have the "black tag" ZF, which is notorious for its "box of rocks" noise straight from the factory, due to its straight cut teeth. No worries.
Old Jan 16, 2005 | 05:12 PM
TD-Machines's Avatar
TD-Machines
I get the same noise.
ClarenceT's Avatar
ClarenceT
Same here. Worried me at first, then i read that it's harmless - got used to it quick.
Old Jan 16, 2005 | 07:24 PM
91z07's Avatar
91z07
Thanks for your replies!
Old Jan 17, 2005 | 08:45 AM
Atok's Avatar
Atok
Normal. My '95 has had this noise for years. I talked to a tech at Rockland Standard Gear he assured me it's a normal sound for a ZF S6-40 transmission. Some are louder than others in neutral but they all do it to some extent. Also, due to the fairly straight cut gears, 1st to 3rd gears are noisy (whine).
Old Jan 17, 2005 | 02:15 PM
Kara's Avatar
Kara
Mine has a LOUD whine from 1st to
3rd and in nuetral. Glad I am not the only one, I though something was wrong with my car LOL
Old Jan 17, 2005 | 09:51 PM
TOO_HOTTVETTE's Avatar
TOO_HOTTVETTE
The straight cut gears account for gear whine when you start driving. The idle in neutral noise would be from the dual mass flywheel wearing out, or better said, the ability of the dual mass flywheel to absorb vibration from the engine. This vibration causes the gear rattle in the tranny which is not harmful, but sound like nuts rolling around in there.
Old Jan 18, 2005 | 07:56 AM
Atok's Avatar
Atok
I disagree. The noise in mine is definitly not the flywheel. It did it from new. I replaced the clutch a couple of years ago and checked the flywheel at that time. It's perfect. I know the "rocks in the can" sound you're referring to. We're not talking about that sound. The closest thing I can compare it to is the sound a supercharger makes.
To Clutch/ZF6 question
