Raised dash pad
Old Jan 19, 2005 | 02:42 PM
94coupe6sp's Avatar
94coupe6sp
Default Raised dash pad
Purchased my 94 in Florida and the dash pad is raised (from solar heat?) right up next to the windshield. Because of the steep windshield angle is the best solution having the windshield removed to get at it? Once exposed, is it a matter of glueing it down? Was it glued down at the factory? Thanks.
Old Jan 19, 2005 | 03:30 PM
MyOtherCar's Avatar
MyOtherCar
Veteran: Marine Corps
Sorry to hear of your problem. Had one similar on another GM product when I lived in New Orleans. It was caused by the intense heat beating into the car all day, everyday (some call that Paradise!! ). I tried resolving it by going through the whole process of removing the windshield, glueing the pad down, reinstalling windshield w/new gasket, all to no avail. The external heat blazing through the glass is more than the glue could withstand because of the warping of the dash pad. I wound up purchasing a new dash pad and replaced it. Sigh, ...big project all for naught!
Old Jan 19, 2005 | 04:09 PM
bogus's Avatar
bogus
This topic has come up recently. After a small straw pole, it was determined that 1994 dash pads are more prone to this kinda failure than earlier or later pads.
More accuratly, a trend developed that made us think this was possible.
I would not bother repairing it. Try getting a used pad from a 95 or 96. They seem less prone to this problem.
It is replaceable from inside the car, you just have to take the entire dash board apart.
Old Jan 19, 2005 | 05:11 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
You may be able to get a nice used pad from Contemporary Corvette, link on my site.
Old Jan 19, 2005 | 06:16 PM
1quik91's Avatar
1quik91
Hope you have a heated garage, sounds like a long process.
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
My '95 has been like that since I purchased it. I've learned to ignore it....
Old Jan 20, 2005 | 08:41 AM
94coupe6sp's Avatar
94coupe6sp
Thank you for the advice. I have the dash partially disassembled now as the Delco/Bose Gold Series just got its CD unit and night lights replaced. If I continue disassembling the dash, does the rectangular passenger side airbag panel remain in place or does this need removal as well?
To Raised dash pad
