Windshield
Old Jan 21, 2005 | 08:33 PM
jereo96's Avatar
jereo96
Default Windshield
I'm sure others have had this problem. It is not Corvette specific, but I hope someone can help me with this one. Heater core had a small leak. Leak was repaired. NOW, how do I remove the film off of the inside of the windshield?? I have tried every glass cleaner in the house and it still clouds up at night. Any suggestions??
Thanks in advance,
jereo96
1996 collector edition
Old Jan 21, 2005 | 08:54 PM
drvn2fast's Avatar
drvn2fast
try a microfibre towel dude. i like 'em
Old Jan 21, 2005 | 11:24 PM
myvettesblue's Avatar
myvettesblue
St. Jude Donor '05
try a cleaner called invisible glass i use it all the time works great ,but i dont know about on this particular reason
Old Jan 21, 2005 | 11:28 PM
85 500 horse's Avatar
85 500 horse
You might try rubbing alcohol or if that doesn't work lacquer thinner. If you use that, make sure all your windows are open and are left open for a long time until all the fumes are gone.
Old Jan 21, 2005 | 11:33 PM
myvettesblue
St. Jude Donor '05
the invisible glass contains alcohol so it may work well for what he needs it for but after you see how it works you will probably be hooked on it
Old Jan 22, 2005 | 09:39 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Any glass cleaner will remove the film.
What you are probably seeing is simple condensation, all the coolant is not out of your carpet yet.
Wait until July...the problem will be gone.
Larry
code5coupe
Old Jan 22, 2005 | 11:54 AM
redwing76's Avatar
redwing76
Larry
code5coupe
You've hit the nail right on the head!
To Windshield
