HELP pulling motor & trans
Old Jan 25, 2005 | 09:45 AM
colemanron's Avatar
colemanron
Default HELP pulling motor & trans
1984 If i pull motor & trans together should i go ahead & get fan & radiator out of the way. need to do work on both are would i be better off to separate them & come out top & bottom ?
Old Jan 25, 2005 | 09:58 AM
89sleeper's Avatar
89sleeper
From: The land of 10,000 lakes ,Minnesota 89 coupe 6speed with 383 and 89 roadster 6speed bonestock with XXX low miles
Read this post!
pulling eng @trans
colemanron :
You can aslo check out this post!
engine removal????
clearedforlanding
Old Jan 25, 2005 | 05:32 PM
neverendingproject's Avatar
neverendingproject
yes you pull the radiator and shrod. take either front wheel off. disconnect the c-beam. and motor mounts. then side the hoist in the side and pull it out. (you might need 1 or 2 more people to guide the motor. this is hard to do, you will want to be pasient.
wait till u put it back in good luck
Old Jan 25, 2005 | 07:35 PM
aj1988's Avatar
aj1988
Another reason to pull the radiator is so you can take it in and have it cleaned and pressure tested. It would be a shame to lose a 'new' engine because of a bad radiator. You also get it out of the way if you are going to clean/paint under the hood.
To HELP pulling motor & trans
