Issues with Optispark ?
Old Jan 25, 2005 | 02:13 PM
Gixster's Avatar
Gixster
Default Issues with Optispark ?
After having owned an '86 and an '89, I'm about to get Vette #3. This time, I'm moving to the late C4 era, ala 1994 M6 coupe. I'm picking up the car in a couple of weeks.
I know there have been lots of complaints about the Optispark. Should I just tread lightly with it? Never drive the car in the rain? Pray to the Optispark gods to bless me with good fortune?
Or should I just expect to replace it regularly? Any maintenance that can be performed on it to increase life?
Tracy
Old Jan 25, 2005 | 02:25 PM
myvettesblue's Avatar
myvettesblue
St. Jude Donor '05
i believe the only real problem is when the water pump starts leaking i dont think you need to worry about driving in the rain but when you clean the engine compartment i woud say take care at the front as to not soak the front of the engine with water i just replaced mine but it looked as though the pump had been leaking for awhilei donot think it will go out with a drop of water it takes a little bit. by the way congratulations on your purchase
Old Jan 25, 2005 | 03:40 PM
SilverBeast's Avatar
SilverBeast
St. Jude Donor '05
Yeah, I agree. It's not that fragile, just that, as with all things, the older it gets, the more susceptible it becomes to heat, water, radiator fluid, etc. Make sure the vacuum hose to it is connected and not plugged: that vacuum helps to keep it dry and clean inside. It should terminate in the rubber intake hose, behind the MAF, on the driver side. Congrats on your "new" 96.
Old Jan 25, 2005 | 03:48 PM
MikeC4's Avatar
MikeC4
congats on your "new" '94. Unfortunately the '94 does not have an Opti venting port like the 95-96. I think there is an aftermarket kit you can install to vent the earlier C4 Opti's.
here are a couple of links describing conversion fron non-vented to vented:
http://www.fierolt1.com/lt1_95_up_OptiReplace.htm
http://www.corvettefever.com/howto/16758/
Old Jan 25, 2005 | 05:47 PM
rcolling's Avatar
rcolling
Yep convert from the non vented to the vented:
How many miles on the car and was the Opti already replaced?
The damn thing still usually fails around 80,000 miles and has to be replaced. I went and replaced my waterpump at the same time.
Other than that just avoid spraying any water directly on it and it will run great for those 80,000 miles..
Old Jan 25, 2005 | 06:01 PM
Kwikerthanu's Avatar
Kwikerthanu
St. Jude Donor '05-'06
I figure I'm on borrowed time. Mine has 94,000 on it and according to my mechanic the water pump and optispark haven't been changed. It runs great, and, knock on wood, doesn't have any leaks of any kind.
Old Jan 25, 2005 | 06:36 PM
jabez's Avatar
jabez
Mine had 63 K on it before it crapped out.
I guess I got good use out of it.
Old Jan 25, 2005 | 07:20 PM
Zix's Avatar
Zix
Hey punk! Where the hell you been?
Old Jan 25, 2005 | 07:25 PM
Gixster's Avatar
Gixster
Maaaaaaaan...they'll let anybody in here !
How goes it buddy ?!
As for the car, it has 75k on it, so I guess I'll need to plan on an Opti and water pump in the near future.
Old Jan 25, 2005 | 07:36 PM
bogus's Avatar
bogus
You have some options...
1) convert to a system that removes the high voltage side. LTCC or DelTeq.
2) upgrade to a Dyna-Engineering DynaSpark unit.
3) upgrade to the 2nd gen opti.
4) Add the vent to the existing GM opti
Old Jan 25, 2005 | 11:10 PM
dan6712cc's Avatar
dan6712cc
The opti on my 94 just died, and I had it replaced about 25,000 miles ago with a new waterpump but... the waterpump started leaking so poof there it goes.. My advice would be not to worry about it until you start having problems, then go for a delteq or ltcc unit. I just ordered a delteq today so this should be the last of my optispark problems.
Old Jan 25, 2005 | 11:18 PM
bogus's Avatar
bogus
Originally Posted by dan6712cc
The opti on my 94 just died, and I had it replaced about 25,000 miles ago... the water pump started leaking so poof there it goes.. My advice would be not to worry about it until you start having problems, then go for a delteq or ltcc unit. I just ordered a delteq today so this should be the last of my optispark problems.
I should define LTCC and DelTeq.
They both eleminate the high voltage side. Meaning, no more distributor. The opti stays on as the optical pickup required for the ECM to do it's job (provide timing data)
The DelTeq uses a Cadillac Northstar coil pack to fire the plugs (lost spark).
LTCC uses 8 LS1 coils, each mounted on the valve cover above the plug in question.
This will help reduce optispark failure, GREATLY. But not entirely. The highvoltage side will fail first, mainly cause coolant and/or water gets in and causes severe carbon tracing. Coolant will distroy the opti, because ethylene glycol is seriously corrosive to oil - eats grease!
If your opti is throwing codes, then there is a problem. And no amount of coil packs is gonna fix that.
I expect an opti to last 120k miles, or more, with the high voltage removed.
Another thing, the rotor inside the opti has a tendency to explode when run at sustained RPMs above 6500. This allows you to remove the rotor, and avoid that problem.
DelTeq has come up with a billet cover for the opti, too, to replace the cap! Looks cool.
I have the LTCC and love it.
Old Jan 26, 2005 | 04:49 AM
USA-VET's Avatar
USA-VET
c5!
Old Jan 26, 2005 | 06:17 AM
myvettesblue
St. Jude Donor '05
i really feel lucky mine made it a 126,000 miles guess i done well compared to some of the others i see
Old Jan 26, 2005 | 06:35 AM
rubyred93's Avatar
rubyred93
Mine crapped out at 25,000 miles. The water pump was shot also (very few bearings left). Do yourself a favor and replace the Opti and water pump at the same time. Might want to do plugs and wires while it's apart anyway...that's what I did. It's not cheap if you pay to have it done. Typical cost is over $1,000.00.
Old Jan 26, 2005 | 07:30 PM
redwing76's Avatar
redwing76
What does it cost? Just replaced a coil plug wire on a F-150 and the part was $200.00. $200.00X 8 is a bunch of money.
Old Jan 26, 2005 | 09:35 PM
pettvette's Avatar
pettvette
CI 5-6-7-8-9-10-11 Vet
A guy that work I with has a 93 that he bought new, replaced his water pump and opit at 100k as normal maintaince. It now has 188k and he is thinking about replacing both when it turns 200k. My 95 with 73k still has the original opti,plugs, plug wires, and water pump...Hope I didn't just jinx it...
To Issues with Optispark ?
