Assorted parts-Ujoints, brake pads, brake hoses, license plate filler plate, etc
Assorted parts-Ujoints, brake pads, clutch fork & pivot ball, etc
I have lots of parts laying around that I gathered up for my 1991 Corvette. I'm looking at parting out the entire car, but I'm going to start with some of the spare parts.
I have several brand new sets of brake pads. Most are just OEM style pads. Some are Midas brand (rear pads, 2 new sets in the box), some are "Big A" brand (front pads). These are basically just semi metallic street pads. Nothing fancy, but if you have a daily driven C4 and need stock style pads, these are stock style pads.
$10.00 per set (4 pads, complete front or rear set) plus freight.
I have a new set of PBR "Metal master" pads. This is a performance street pad that is (or at least it was) very popular for performance street/autocross use. These came on an Ed Miller C4HD brake conversion kit that I installed on a '92 Z28 some time ago. I swapped on the Hawk pads (listed below) before ever driving the car. I don't have a box for these, but they are new pads.
$35 plus freight OBO
Oil filters. 2 Mobile 1 filters (PF 454 equivalent) and 3 AC Delco filters (PF 454). New in the box, fit 1991 Corvette (standard small block Chevy filters).
$20 plus freight
Reproduction rubber floor mounted shifter boot (the one that always tears) for a 1991 6 speed Corvette. New in the box/never used.
$25 plus freight OBO
OEM Clutch fork and pivot ball (1991 ZF S6-40, these appear to fit the LT1 and LT5 cars as well). Brand new, never used. ZF Doc referred me to a place that had the last of the NOS factory parts and I purchased a set for my car but didn't install them. These are in brand new, unused condition and are OEM parts. I'm not sure if you can actually buy these anymore (if there are still some left, my price is probably too high, if there aren't anymore left, it's probably low....if you need them, lets talk).
$295 plus freight OBO
ZF S6-40 (1991 Corvette 6 speed) "shift shaft" (the rail in the transmission that has the shift pattern in it). I converted my car to a "crash through" version and removed this one from my trans. These are a couple hundred dollars new (or the new one I bought was).
$45 plus freight
I also have a Racetronix C44 1989-1996 Fuel Pump Wiring Harness
http://www.racetronix.biz/itemdesc.a...WH-014&eq=&Tp=
Still new in the package.
$39.50 plus freight OBO
Oil pressure switch. New in the box. This is the one that illuminates the "check gauges" light on a '91 Corvette (it's located back by the distributor). PN DR4006, other PN PS222.
$5.00 plus freight
Pics on request. If you need something that's listed, drop me a line. If my price is out of line, let me know and I'll gladly work with you.
Email me at:
trackbird (at) gmail dot com
$20 plus freight
$45 plus freight
$5.00 plus freight
Email me at:
rear window drain kit
Do you still have the rear window drain kit?? if so if so I want it.. where do i send my pay pal payment.. thanks, gary
I have several brand new sets of brake pads. Most are just OEM style pads. Some are Midas brand (rear pads, 2 new sets in the box), some are "Big A" brand (front pads, 2 sets in the box) and one set is "Brakebest" brand (rear pads, 1 set in the box). These are basically just semi metallic street pads. Nothing fancy, but if you have a daily driven C4 and need stock style pads, these are stock style pads.
$12.50 per set (4 pads, complete front or rear set) plus freight.
$50 plus freight OBO
I have a used set of Hawk HP+ pads. This is a step above a street pad and they are commonly used for dual purpose cars (street/autocross and light track days). Approximately 70% of the pad material is left.
Front brake hoses, new in the box.
$20/pr plus freight
Front license plate cover. Factory 1991 Corvette, red factory paint (likely faded a bit). Good physical condition.
$75 plus freight OBO
Moog "Super Strength" U-joints. I have four, brand new and still in the box (PN 231) that I purchased for the rear half shafts but never installed.
$60 for all 4 plus freight OBO
$20 plus freight
TPIS Billet IAC housing. I bolted this to my throttle body, then I found that my throttle body didn't fit the intake hose on my 1991 Corvette very well, so I ordered a TPIS throttle body. The car was never started with this installed, it was bolted on and then removed. The TPIS throttle body came with one, so this is a spare. Excellent condition and you save money.
http://www.tpis.com/part_images/1.IAC001
$50 plus freight
Black plastic letters that fit in the "CORVETTE" lettering on the rear bumper of a 1991 Corvette (and up). I purchased them from a vendor here on the forum and they are still sealed in the package.
$20 plus freight
TPI throttle cable brackets. I have two that appear to match. They came off of my 1992 Z28 (350 TPI) and my 1991 Corvette. I have no idea what they are worth, so I'll put up a price and take offers.
$25/ea plus freight
$350 plus freight OBO
Haibeck Automotive oversized tilt column pin. I purchased this and never installed it. It's still in the bag from Haibeck. This will help with the slack/wiggle that develops in the steering column over time.
$45 plus freight OBO
Weatherstripping pieces:
I have the two pieces that go from beside the dash up to the lower edge of the trim around the front window. These were about $60/ea when I bought them. They are new/never used. Ecklers calls it the "Corvette dash to door windlace weatherstrip"
$100/pr plus freight OBO
Front window weatherstripping (around/above the windsheld). New/unused.
$125 plus freight OBO
Rear roof weatherstripping (seals the back of the targa and the rear of the side windows. New/unused.
$110 plus freight OBO
I have a new "Corvette rear window drain kit" for '84-'96 Corvettes. New/never used.
$5 plus freight
Email me at:
$20/pr plus freight
$20 plus freight
$50 plus freight
$20 plus freight
$25/ea plus freight
$5 plus freight
Email me at:
pay pal complete
Hey Kevin, thanks for the pm..Pay Pal is completed, I rounded it up to $10.00 for the rear window drain kit. I figured it would cover the pay pal fees and what you quoted me for the freight. I sent me addy with the payment, Thanks, Gary
Fiberglass targa roof from my 1991 Corvette (I believe 89 to 96 are the same, but check that before you buy). Good condition, brand new weatherstripping (it hasn't been installed since the new weatherstripping went on, I switched to the smoked plastic roof). The headliner is loose in spots, otherwise it's red and in good condition.
$625 OBO local pickup only. (I get through Washington, PA, Morgantown, WV, Cumberland, MD, Hagerstown, MD, Martinsburg, WV, and Winchster, VA area from time to time and I can possibly arrange to meet someone in those areas).
$20/pr plus freight
$20 plus freight
$50 plus freight
$20 plus freight
$25/ea plus freight
$45 plus freight OBO SOLD
$5 plus freight
Email me at:
$20/pr plus freight
$20 plus freight
$50 plus freight
$20 plus freight
$25/ea plus freight
$5 plus freight
Email me at:
I have someone in front of you for the shocks. I should have a socket (assuming a '91 fits in the earlier cars....if this is an '86 as your screen name suggests). I haven't pulled the front end apart yet, but I should get to it fairly soon.
Yeah I had a 86 now I have a 91 and it's the left front turn socket on the side
It was from Ecklers. I think most of it was the lower priced option, except maybe the rear window weatherstripping...I think it was the middle grade (I can try to look at my account to verify). The rear window seal was on the car (garage kept and driven 700 miles) and is in very good shape if anyone needs it. The rest is new in the package that I have listed in the original post.
