TPIS long tube headers with cats
A local shop will install coated long tube headers with emissions on my 1996 LT4 if I supply parts. They ask me to bring two 02 simulators, two hi flow cats, and an X pipe. I called the header vendor to order parts and got really confused. The vendor said you don't need 02 simulators if you run cats. Can someone explain why the 02 sims are needed?
Does using 02 sims imply that I wont be emissions legal in Texas?
What year is your car? Mines a 93 and I only have two O2 sensors.
The later cars had more O2 sensors and maybe you need O2 simulators to plug some of the holes?
If they want you to use O2 simulators in place of ALL O2 sensors then I dont think thats right. Why not use real O2 sensors?
The TPIS long tubes I got for my 93 had holes in them for the O2 sensors.
My current setup is long tube headers(no AIR or EGR) - heated O2 sensors - no cats - stock exhaust
1 Post
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
I went to Cruise-In V with Vetteweiser
I have a 96 LT4 with the TPIS long tube headers and all I needed was the headers and the 2 high flow cats ....
Location: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
The guy probably just doesn't want to go through the trouble of welding in O2 bungs into the exhaust. Its obviously a custom setup. You could probably just make the request for the sensors to stay in place. If he give you jibber jabber about things ask for it anyway.
ODBII (1996) cars have four O2 sensors. Two up front and two behind the cats. you should use 02 simulators if you are not using cats because the rear sensors are there to monitor the cats.
St. Jude Donor '03
Originally Posted by sothpaw2
Does this mean, for a 1993 w/ OBD I, I have only 2 O2's, in front of the cats, and I will not need O2 sims but rather just to put fresh O2's before the new cats in the new set-up? This is for EM LT headers.
The polished part above is the clamp at the collector. To the left of the clamp is a small portion of piping before the catalytic converter (noted by the color change). Here is another view from the rear, looking forward.
You can see here the additional pipes that are needed to go from the cats to the cat-back system. Your Xpipe would go in place of the dual-chambered resonator at the top of the above pic. As you can see, there is considerable distance between the headers & Xpipe.
You don't need O2 sims (as previously mentioned), and just make sure this shop really knows what they're doing before you let them get knee-deep into your header installation. Best of luck!
St. Jude Donor '03
Thanks for all the good info everyone. (Perfusion), where did you get the X-Pipe?
Thanks VictorRussell'92, maybe this is a good place to ask this question while I have a few ears. What is the difference between X-Pipe, H-Pipe, and Y-Pipe. My installer asked for an X-Pipe. I see Perfusion uses an H-Pipe. What determines which to use?
Hope that helped a little.
Cool, then it sounds like I only need those pipes that connect the cats to the catback (H-Pipe) thingy since I already have the Corsa catback. Is there a part number for those pipes or is that custom fabricated?
where you get those high flow cats at?
I need to get some!
ALSO:
Get uncoated and I can ceramic coat any set of LTs for only $188!!!!
this includes coating inside and out, all preping of materials, 3 yr labor warranty, and a lifetime limited rust warranty!
This should save you alot of $
and even if you get stainless get them ceramic coated
stainless is not rust proof just rust resitant!
thanks alot
your firend
Sean Blanton
slimshaby@mindspring.com
let me know!
I need to get some!
ALSO:
thanks alot
your firend
Sean Blanton
let me know!
my prob is that I can't really find high flow cats that will fit between the collectors and the resi!
and my LTs dont have o2 bungs so the extra little space is for the o2 bungs in the collectors
St. Jude Donor '03
Yeah don't go messing with your Corsa system its already about as good as its gonna get!
1 Post
Originally Posted by redbullapril23
how much were the random tech cats each?
thanks your friend
Sean
thanks your friend
Sean
