How Far Is Too Far?
I use the NX on my L98 86 vet.The cheap one that you put holes in the air intake tube and hope for the best.I have mine about 4 inches in front of the throttle body.
ON my 94 I use a barry grant kit plate system.
Puts out a lot of power and doesn't take as much nitrous as the NX kit.
The closer you have it to the TB the harder the hit will be. That's why the guys that run the plate systems say they get more power from it. 100 hp is 100 hp no matter how you get it.
I run my NX spray right in front of the IAT sensor. I would think that if you put it in front of it you may have a problem with the sensor reading VERY COLD air temps.
