heater core replacement
Old Jan 29, 2005 | 01:13 PM
corvette1271's Avatar
corvette1271
Default heater core replacement
i have been reading the threads concerning heater core replacement, and i have neither the place or the time to do mine myself. with 95k on my 94 coupe, i think it is near overdue. just called the local chevy dealer here in marysville wash and their quote was $617 parts and labor, and just wondered if anyone else in this area had any other sources/work done that was less expensive and with good results?
Old Jan 29, 2005 | 02:07 PM
redbullapril23's Avatar
redbullapril23
is there anything wrong with the heater core? like is your air not getting hot? or are you just trying to replace it before it goes bad?
its a PITA to replace....Because I removed my hole ac system from mt lt1.
thanks alot your friend
Sean Blanton
best
Old Jan 29, 2005 | 02:24 PM
bogus's Avatar
bogus
As Sean asked, are you not getting hot air? Is there a smell of coolant?
The smell of coolant is the real cause of the failure. If you are not getting hot air, something else is messed up with the climate control.
To replace the core, pretty much requires taking the car apart and putting it back together. That estimated price is pretty good, really.
Old Jan 29, 2005 | 02:33 PM
corvette1271
Default ....heater Core.....
....no, bogus, at this point everything seems to be fine....just thinking of the high miles.....and thinking of a measure of prevention and taking care of a problem before i get out on the road with it.......
Old Jan 29, 2005 | 02:40 PM
84whitevette's Avatar
84whitevette
Corvette1271,
I was also worried about the same thing when I got my vette (84 w/ 98,000 miles). The reason being is I'm going to be replacing the carpet and afraid that if it ever goes it will leak all over the new carpet. I had this happen to another car that I restored and had to replace the carpet again !!! Anyhow, I did not change it out because its not showing any signs of failure. I do carry a piece of hose in case it does leak so that I could bypass the heater core if it happens while I'm out and driving. I may change it out when I get into the dash to install a new radio and "breadbox" delete. So enjoy the car, if it leaks fix it then !!!
Pete
Old Jan 29, 2005 | 08:45 PM
bogus's Avatar
bogus
this job is not for the feint of heart or wallet. I would not bother unless it leaks.
If you are not getting heat, there is another reason... something with the heat mixing door or something along those lines.
Old Jan 29, 2005 | 09:52 PM
C4396roadster's Avatar
C4396roadster
Just did mine for the 2nd time that is the shop repaired it, both times same shop.....the advice is to make sure you get factory part on this and dont cheap out. I tried to save a few bucks and this is the result for the long run and the 1st core was 3 years old not driven and the 2nd core is 1month old ac delco part cost me $380 with parts installed..
Old Jan 29, 2005 | 11:21 PM
hngacurv's Avatar
hngacurv
You can do it in a day if you. Take your passenger seat out for more room. Search for past threads by Fastguy on this.
Old Jan 30, 2005 | 12:37 AM
Rich Silvestris's Avatar
Rich Silvestris
St. Jude Donor '05
The core on my 87 went at around 155,000 (this past year). I've owned the car for 5 years. There was no sign of prior work under the dash, and the hose clamps on the heater hoses were black (sign of factory install?). The first sign of failure was a fogging on the windshield and when I took it apart a couple of weeks later, all the leaked coolant had beeen caught by the foam on the hush panel, no coolant on the carpet. In short, you may be worrying too much about this.
Old Jan 30, 2005 | 10:28 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
I believe in the "ounce of prevention" saying. As you can see by my avatar, I just did my core in my 85 which has 92,000 on it. I have the interior out for replacement and decided I didn't want coolant on my new carpet. When I pulled the old one out I knew I had done the right thing. They wear from the inside out and the top tank on mine was so flimsy it's a wonder it hadn't started leaking. As was stated, don't go the cheap route, either install GM or equal. I went with NAPA and was amazed to see how much stronger the new one was next to the original. It IS a PITA to do though.
Old Jan 31, 2005 | 11:23 AM
corvette1271
Default ......heater core....
[QUOTE=bogus]this job is not for the feint of heart or wallet. I would not bother unless it leaks.
after a second conversation with the service manager i was assured somewhat when he told me that they do not do very many of the 94s.......what that meant could be anyone's guess....that most everyone does theirs themselves, and/or that mileage is just now reaching the point on later c4's that warrant heater core change out. i think that i am going to accept your advice bogus, about the nature of the job.....i already have one heater core experience on a 69 ford p/u years ago.......it took 8 hours to get into it, 2 min to change the heater core, and 8 hours to put it all back together......
Old Jan 31, 2005 | 11:46 AM
lildrgn's Avatar
lildrgn
OK, im confused.
I have an 88, mild modification.
Recently my heat has just quit. I turn on the heater, and ice blows on me. I get the very very faint smell of coolant when its on.
At first, I thought it could have been my thermostat since my temps were just going crazy. Well a new themostat fixed the temp problem, and gave me a little bit of heat for like 10 minutes. (also had the coolant power flushed)
So, could this be the heater core?
Old Jan 31, 2005 | 12:27 PM
sothpaw2's Avatar
sothpaw2
[QUOTE=corvette1271]
My '93 has gone through no less than 2 cores. First at 48k mi, then at 72 k mi. Both GM. The 2nd time, I bypassed it. I'm not paying for it again. Was $350, parts & labor locally for the core.
I was able to stop the leak well enough to drive by just stuffing rags in over on the passenger side. So, keep rags, hose to bypass it, and don't worry.
What I can't figure out is why these GM cores are soo weak? Obviously not a very good choice of metal alloy for corrosion resistance.
Old Jan 31, 2005 | 12:45 PM
bogus's Avatar
bogus
Originally Posted by lildrgn
OK, im confused.
check the vacuum canister. Under the left headlite, there is a vacuum canister that supplies vacuum for the climate controls. Make sure it's connected and working.
The heater valve is on the inlet pipe to the heater core on the passengers side firewall. Follow the hoses. It's a vacuum servo, with some linkage. It should move.
Old Jan 31, 2005 | 06:12 PM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
My glass started fogging up on my '85 and I smelled the dreaded coolant smell, so I knew the core was going south. If this isn't happening in your car, I'd leave it alone. The one I replaced was the one that came in the car when it was new. Not bad for 134,000 miles and 20 years of age. I hope the one I put in lasts as long! If your mind is made up to replace it, do it yourself and save your money. It's not as much a nightmare as everyone makes it out to be. I removed the passenger seat to do mine which made the job alot easier. It's a pain lying on your back taking things apart to get it out. Just take your time. I did mine after work two nights in a row. Took about four hours to get it done. One thing you might want to check out, your C4 has an airbag on the passenger side. I'm sure you'll have to disable it before you start tearing into the underside of your dash. Take a look at everything and see if it's something you want to tackle. Good luck with your car. Enjoy it!
Old Feb 1, 2005 | 08:06 AM
Tom Piper's Avatar
Tom Piper
My experience has been that, if the coolant is changed at least every two years, I've never had to replace a heater core or radiator for leaks -- even on 200K mile vehicles....and I've owned many.
The problem I've had is when I purchased a used vehicle and didn't know the service history -- then, even though I changed the coolant, I still lost the heater core or radator. Probably due to neglect by the previous owner(s).
Tom Piper
Old Feb 1, 2005 | 12:10 PM
sothpaw2's Avatar
sothpaw2
Tom Piper
I agree with you there, Tom-- my first core was bad when I bought the car at 5 years old w/ 42 k mi. I bet the coolant was original. The car had other signs it was not cared for--paint scratches, ugly, careless touch up, pitted rims from driving in salt&not rinsing. Unfortunately, the core did not cause a coolant leak and the dealer wouldn't fix--even though heat was not very hot at all.
This doesn't explain why my 2nd core lasted only an additional 4+ years.
I did change coolant.
To heater core replacement
