I've got a set of 113castings that have been machined with 2" intake, 1.6 exhaust. They've been cut with the fastburn style combustion chambers making them around a 62cc, which from what I understand is 4cc up from the stock 58cc.
I'm bolting this up to a SR manifold/plenum and 219 cam, 1.6rrs...
What kind of compression ratio should this be? Is there anything I should keep in mind with this set of heads?
I'm also debating on a set of pistons, but haven't made a decision on them yet - Mostly because I'm not sure what would work best for my application. Any advice? I'm shooting for around a 10 - 10.5 CR
And slightly off topic, with those heads and those modifications, would it warrant 1 3/4s LTs rather then 1 5/8ths? I know theres a whole can of worms opened there, but my thought is that the car is already really torquey, I don't see the lowend gaining anything because the car spends most of its time off the strip, and I won't gain as much on the high end with the 1 5/8ths as I will with 1 3/4s. Plus, exhaust from the heads is around 202CFM, and I'm not sure which header would be more appropriate for amount of flow.
Static CR is derived from the bore, stroke, combustion chamber, quench, head gasket bore, piston reliefs/dish/dome, and where it is in the hole at TDC. We need more info
I've got a set of 113castings that have been machined with 2" intake, 1.6 exhaust. They've been cut with the fastburn style combustion chambers making them around a 62cc, which from what I understand is 4cc up from the stock 58cc...
How did they cut them with a "fastburn-style" combustion chamber? If you have any pics that would be cool. As far your question we do need more information.
If you want to ASSUME a compression ratio with the stock 58 cc chambers, it is simple arithmetic to check the cr with 62 ccs or any other size chamber. There was a post like this recently.
The 1 5/8ths" tube headers won't limit your high rpm performance one bit. They WILL boost your low speed response. Afraid if too much torque???
If you know the stock CR you can easily calc the potential new value.
What year L98 is it?
Did you machine the block, i.e. deck it?
Did you (will you) change pistons?
What was stock CR?
As mentioned, the question on LT header size is do you want to gain low end or high end with them. LPE shows the recommended crossover between 1 5/8" to 1 3/4" at around 350-400chp. They also mention that you can increase low end torque with an 8-10" collector extension.
What was stock CR?
Year is '91
Block Decked? No.
Have I changed pistons? No. Am I considering it to opt for a better CR? Yes.
Stock CR is stock for a '91 as I haven't touched the motor yet, personally.
Thanks for the help everyone. I had my heart set on the 1 5/8ths EMs, I just needed to find a matching Y-pipe, I'm going to stick with that plan. : )
Year is '91
Block Decked? No.
Depending on the condition of the bores and pistons, decking the block is a better way to raise the cr.
