hheellpp does this thing come apart
Old Jan 30, 2005 | 04:36 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
Default hheellpp does this thing come apart
i'm trying to pull the wire harness out of my 90 so i won't have it in the way or hanging loose. does this come apart or is it just for passing through a bulkhead? the heater/ac box is next to it. thanx
Old Jan 30, 2005 | 05:33 PM
fsr402's Avatar
fsr402
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Looking at the picture I would say no it doesn't
Old Jan 30, 2005 | 05:47 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
You have to undo it from inside the passenger cabin. There is a vacuum line connection going to the HVAC system as well.
Old Jan 31, 2005 | 01:41 PM
Jeffvette's Avatar
Jeffvette
I found a couple of pictures from my removal. I don't have anything really showing that part of the harness very well.
Old Jan 31, 2005 | 01:51 PM
Sleazy Rider
thanx for the reply and the info. 91vert had replied to this on another forum telling me the same thing, and by the time i read yours, it was a done deal. but now i'm off and running. thanx all, another little tech question answered to help us all.
Old Jan 31, 2005 | 01:56 PM
MikeC4's Avatar
MikeC4
surely this is a male/female connector, and it will come apart. It may take some careful prying/wiggling and persuassion, but it will come apart. Also, GM is famous for having interesting connector locks, so look for a "locking mechanism" on this harness connector!!
Good luck with it!
Old Jan 31, 2005 | 02:06 PM
Sleazy Rider
Good luck with it!
i thought the same thing. a buddy of mine told me it does come apart, and he's a vette mech, own his own shop. if you look at the pic, you will see what looks like a grey clip, and on the opposite side is a hole. well i tried to squeeze the prongs together and push apart, no luck. anyway, unconnecting the 4 connectors and 1 vacuum line was no big deal and the harness just pulled through. this 90 is different than my 89
Old Jan 31, 2005 | 02:33 PM
CFI-EFI's Avatar
CFI-EFI
If it isn't a connector, why is it there?
RACE ON!!!
Old Jan 31, 2005 | 03:44 PM
hz900's Avatar
hz900
RACE ON!!!
I took mine apart, as in the black casing from around the wires and I can say that it is not a plug. The wires go straight through. The black thing that looks like a plug is just there to hold the harness in place when it goes through the fire wall.
Old Jan 31, 2005 | 04:53 PM
Sleazy Rider
thats exactly what it is. its a bulkhead fitting to hold the harness in place while going through the firewall to prevent chafing the wires and to prevent a water/anything leak between the outside and the pass compartment
To hheellpp does this thing come apart
