electrical question
Old Jan 30, 2005 | 06:50 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Default electrical question
I am upgrading my 85 inside rearview mirror to the later type with lights in it. The two wire socket is obviously positive & negative wired with the switch on the mirror turning the lights off & on. The 3 wire plug is where my problem lies, when I use jumpers, all I can get to light is the small yellow light. I'm assuming that this plug is the one that is connected somehow to the interior light timer but where do the 3 wires come from that plugs into it? I think the mirror is out of a 96. I really want the lights to come on as I get in and go out by themselves. Any help will be appreciated.
Old Jan 30, 2005 | 06:58 PM
sniperdiver37's Avatar
sniperdiver37
Not real sure about that one but here is a guess.
The 3 wire plug might be for a "auto Dim" in the 96 set up.
Just find the wire that turns on the light and run a jumper to your door switch. Find the ground and... lights Close the door.... no lights
Just a guess, hope it helps.
Jeff
Old Jan 31, 2005 | 09:59 AM
Midnight 85
ttt
Old Jan 31, 2005 | 01:55 PM
John Robinson's Avatar
John Robinson
Default Yellow Light
On my 93 coupe that small yellow light comes on when I turn on the headlight and it is connected to the dash light circuit. It puts a soft light over the shifter and ash trays.
Old Jan 31, 2005 | 02:20 PM
JCAIRE2's Avatar
JCAIRE2
Old Jan 31, 2005 | 03:15 PM
Midnight 85
Thank you John so much, I finally had it all figured out except the yellow light. Now I can set that up too. This forum is fantastic.
To electrical question
