What about this booster?
Has anyone used or know someone that has this power brake booster installed? The original one is plastic and costs over $300.00, $439.00 at a Chevy dealer.
This one is from MidAmerica and costs $169.99
Corvette Central has one that looks the same for $164.95
What do you think?
It's a booster, not a timing gear. If it starts leaking, well just use some leg muscle and stop the car.
Get the booster, save some money. I'd much rather have a metal one on there myself, and if mine goes out I'm getting that exact same thing.
There are few things you should find out before buying it if you can:
You should get this info for both the original and the aftermarket booster to compare:
1. the boost ratio
2. boost run-out
3. maximum travel
1 gives you the amount of assist
2 gives you the maximum assist before the pedal goes 1:1
3 gives you the travel, which is important since it needs to be as least as much as the travel of the master cylinder to max pressure.
1 can be different from stock, you just want to know if your going to have more or less assist so you know how the pedal effort will be effected.
2 is should be at least as much as the original to make sure you get maximum brake power.
Just because it fits doesn't mean it work operate the same as stock.
Also, if Mid-America can tell you, ask who manufactured the booster. And yes, some are made in China. So are many OE boosters from Bosch and Continental-Teves, the two largest brake suppliers in the world.
What do you think?
Crawling back under the dash to remove the booster is sooooooo painful..........
Also, I checked in the old booster if there was an adjusting nut on the rod and found that there is none. So I must conclude thet the new booster does not have it.
What now???
This was before I found out about the metalk version, if I had only known . . .
Still going strong though.
Jake
What do you think?
Good luck. Read on:
I washed the car since it was sitting for 5 weeks and was very dirty. Took it out for a test drive and the brakes seemed to work properly. Then I decided to get some take-out for me and the wife and drove to a nearby restaurant. Was doing about 40 mph when I decided to test the brakes by stopping hard. When I stepped hard on the brakes, I heard a sharp crack and was left with MINIMAL stopping power. It was so bad that I had to downshift to get the car to completely stop. Then , after stopping, I pressed the brake pedal with my left foot and with my right foot gave it a little gas in Drive. The car shot forward This does not sound good. I got my food and drove back home VERY SLOWLY . I am SO COMPLETELY PISSED .
There is no way, in my opinion, that a person with mechanical inclinations and some basic tools can screw up a brake booster installation. It is straightforward although unconfortable but anyone can do it. The booster only goes in one way, there are only 2 bolts holding it to the firewall, only 2 bolts for the master cylinder, and a cotter pin and 2 washers to secure the connecting rod to the pedal.
So I must conclude that something INSIDE the booster broke.
Any ideas before I take everything apart? Definitely I am calling MidAmerica Motorworks first thing Monday morning and tell them I am returning the booster because it broke. Can you imagine this happening at a higher rate of speed and having to hit the brakes during a panic stop? The car (and me) would have been demolished.
Any opinions on where can I have gone wrong or is it just bad luck I got a bad booster?
I still believe that when you're dealing with the brake system, unless you go high performance, get OEM. Don't buy parts from a country whose workers get paid in a year what you make in a day.
Take a close look at the booster, you'll probably find the crack. Use a strong drop light and, if necessary, a mirror to be able to see the back side.
They ususally crack on the inboard side, down low toward the exhaust which is the weakest point due to the exhaust heat. In your case, though, since it's new the crack could be anywhere.
Let us know what you find.
Jake
.Maybe the quality is better
So far so good.
