Datamaster Run
Old Feb 1, 2005 | 10:57 PM
RedRiderZR1's Avatar
RedRiderZR1
Default Datamaster Run
I just put in new O2 sensors and I am not sure what the readings are supposed to be. I would appreciate any help you could give me. Something on the O2 readings dont look right (seen other peoples graphs).
Thanks.
Greg
Old Feb 2, 2005 | 12:19 AM
krivera's Avatar
krivera
what are you looking for the air/fuel under WOT???
Old Feb 2, 2005 | 02:01 AM
RedRiderZR1
Looking for what the O2 Mv readings should look like on the graph. Above 1500 RPM they look the same on the graph (Quick up and down spikes). At idle or just off idle the right O2 sensor spikes up and down alot, while the left one goes up and down slowly (slower on crosscounts). These are brand new GM sensors I just put in today. Doing the same as before I changed them out. So I figure there is something off.
Greg
To Datamaster Run
