4+3 tranny Questions
Old Feb 3, 2005 | 05:25 PM
GTR1999's Avatar
GTR1999
Default 4+3 tranny Questions
Hi guys,
I'm not a c4 guy, I run C3's. I can rebuild just about anything on a C2 or C3 and a guy asked me about rebuilding his 87 4+3. I've done both Muncies and ST-10's but not a 4+3. Is there any info here on this job? Where do you get part kits from? I was told the 4 speed portion is still a ST-10 and the overdrive is similar to a automatic?
I passed on the job but would like to read up on it.
Gary
Old Feb 3, 2005 | 07:25 PM
steveb's Avatar
steveb
Here is a pretty good write up on rebuilding the overdrive section.
http://corvetteactioncenter.com/kb/q....php?qstId=115
Old Feb 3, 2005 | 07:37 PM
85 500 horse's Avatar
85 500 horse
I've heard that rebuilding a 4+3 is incredibly expensive and difficult. It takes someone with the correct knowledge to correctly rebuild one of these tranny's. I'd advise him to spend a little extra money and ditch the 4+3 and put in a 5 speed.
Old Feb 3, 2005 | 07:49 PM
bigjack's Avatar
bigjack
Default 4 + 3
Can offer minimal input. 4+ 3 was apparently made by Doug Nash Trans. (now Richmond Trans.). The rear, automatic section, I'm told, is rather like the old Powerglide. I recall an ad in the major car mags(Car Craft/Hot Rod) by a guy in N.Y. that offered rebuilding and parts/kits. I'll re-post if I can find any further info.
Another thought is replacement of the 4+3 with a Richmond 6 sp.(expensive but a "bolt in" or Keisler's T-56(same scenerio, in the neighborhood of $3200).
Old Feb 3, 2005 | 07:55 PM
frank j. moran's Avatar
frank j. moran
Originally Posted by gtr1999
Hi guys,
Gary
they can be rebuilt and are not too difficult if you read and reread the instructions that are in this thread by David Fulcher, he knows them inside out and has helped me with one. hard parts are the problem hard to get, a soft kit is available. Bearings are also avialable, the thrust washer on the very bottom can be hard to come by, but I have seen them and bought them.
Old Feb 3, 2005 | 08:16 PM
bigjack's Avatar
bigjack
Default P.s.
For historical info, see Http://corvetteobsession.homestead.com.
Try www.pipersauto.com for possible parts and rebuilt units (this is 5 Speeds by Darrell). Good Luck. The "obsession site" offers some interesting facts(?) about the strength, etc. of the ole 4 + 3.
Old Feb 3, 2005 | 08:46 PM
kopbet89c4's Avatar
kopbet89c4
This might be a little OT, but is a 4+3 a manual or auto? Does it have a torque converter? Any pics on what they look like, e.g. how you shift them? Hmmm... I just wanna fulfill my knowledge about the earlier C4s.
Old Feb 3, 2005 | 09:18 PM
USAsOnlyWay's Avatar
USAsOnlyWay
The obsession link doesn't work...
Old Feb 3, 2005 | 09:20 PM
NightFlight's Avatar
NightFlight
It's a manual 4 speed with 'overdrive' in 2nd - 4th gears; thats where the 'auto' part comes in, as well as the name. You shift between 1st - 4th like a regular manual. However thier is a button on top of the shifter you push (without using the clutch) to put it in 'overdrive'. Normally I don't use the over drive in town, only when cruising at hiway speeds. Once in or out of overdrive it will stay there as you shift gears. Also, if you're cruising in overdrive, lets around 65 or so, and jump on it, it will pop out of over drive and give you that 'lower gear boost' to get you up where you need to be . Personally, I think they are a lot of fun to drive.
Old Feb 4, 2005 | 10:30 AM
GTR1999's Avatar
GTR1999
Thanks guys, I don't usually take in C4 work because I'm not familar enough with them. This guy has over 100k on the car and wants to get the tranny fixed and can't find anyone who will rebuild it. Several vette shops will exchange it. I'll check those leads you gave me
Gary
Old Feb 4, 2005 | 10:37 AM
kopbet89c4's Avatar
kopbet89c4
Hmmmm.... Very interesting indeed. I'd like to see one up close.
Old Feb 4, 2005 | 12:03 PM
GTR1999's Avatar
GTR1999
Very good reference, doesn't look too bad. Thank you,
Gary
Old Feb 4, 2005 | 12:43 PM
scorp508's Avatar
scorp508
I've you've done a Borg Warner Super T-10 then you can definitely do the 4-speed part. It uses the CC (2.88 1st gear) gearing setup. The O/D part takes a little patience, but should be doable with a couple specialty tools (or make up your own).
Parts are too bad for it unless you break a major piece like the cluster gear.
To 4+3 tranny Questions
